hello.
need an ecu and loom from a v6 ford, don't care if its 2.5 ro 3.0 as I have both engines however
its going on a jag motor so from the front i need
mondeo twin fans and shroud.
fan relays
thermostat housing
alternator - IF the loom is 5 or 6 speed I need the 2 or 3 wire alternator from that loom I think
need the ecu and the engine loom - AND the injector loom
need the single coil pack and the ht leads
I need at least the obd-2 port and wire tail
transponder ring and wire tail/plug
little LED and wire tail.
need the fuel pump and loom and the charcoal cannister and return and the fuewl filter, - for the mount and fittings
roll over cutout
evap vapour return doofer
i want the loom with all the giblets connected to it - crnk positin sensor
knock
injector 1-2-3-4-5-6
cam position sensor
need the mass air flow at least with the loom there
need the iac on it
need the battery and the cable
maybe both fuse boxes
also need a 2.0 jaguar x type throttle body with the built in iac
would like st220 stainless manifolds with cat deletes but the cans and the 4 sensors, still connected in the loom bank 1234
prefer it all 2.5 v6 too rather than 3 litre.
thanks
i am in london and would prefer to collect
cant buy a complete donor
fan relays
thermostat housing
roll over cutout
knock
cam position sensor
need the iac on it
thanks
