v8ian
Jan 24, 2023 19:48:02 GMT
Hi Chaps. I have a stainless exhaust to modify on one of my projects, I am fairly certain I can get this done with my ESAB mig, I bought a 1kg drum of wire, set the welder to where I guessed the setting should be, and using a bit of ss wire, welded an acceptable bead, I said bit, because the drum the 1 kg came on has a small bore and my welder had a fixed large (2"ish) spigot that appears it cant be change with major unwanted surgery, does anybody know where I can get a 1kg drum of ss wire with a big bore. I'm not overly keen on buying a big drum as I only have about half a linear mtr to weld, any suggestions please,
Darkspeed
Club RR Member Number: 39
stainless mig welding wire.Darkspeed
@darkspeed
Club Retro Rides Member 39
Jan 24, 2023 20:38:04 GMT
Wind it onto your your mild steel roll and use it from there.
v8ian
Jan 24, 2023 20:39:57 GMT
I think that will be the plan
Darkspeed
@darkspeed
Jan 24, 2023 20:50:43 GMT
I think that will be the plan And you won't need me to say keep the tension when spooling it from one to the other but I will say it anyway
v8ian
Jan 24, 2023 21:23:23 GMT
I think that will be the plan And you won't need me to say keep the tension when spooling it from one to the other but I will say it anyway And the SS wire is sprung, more like Piano wire than welding wire.
v8ian
Jan 25, 2023 14:07:32 GMT
You need to use pure argon when welding stainless. Also you should change the liner and tip to a fresh one i.e. no rust/contamination
Darkspeed
@darkspeed
Jan 25, 2023 15:01:55 GMT
Argon mix is fine and no need to change tips and liners.
Jan 25, 2023 16:19:02 GMT
Agreed, welded stainless with my mig with Argoshield and dirty tips. Acceptable weld, no-where near as nice as tig of course.
