Mar 17, 2023 12:19:16 GMT
For sale : ford 8 inch axle complete . 51” flange to flange , 54.5” overall 3.00 diff 4 stud ford 4x108 pattern Turns and is complete, no longer required and surplus . Collection from London / Kent please £250 Any questions please pm me or get me on 07969696746
mylittletony
Club RR Member Number: 84
Ford 8” rear axle mylittletony
@mylittletony
Club Retro Rides Member 84
Mar 17, 2023 13:04:12 GMT
HARDCORE is 8" enough for you, or do you need the full 9 to be satisfied?
Ford 8” rear axle HARDCORE
@hardcore
Club Retro Rides Member 190
Mar 17, 2023 13:35:46 GMT
Hmmmm. How do these compare (strength-wise) to the Atlas? And is there a similar array of diffs and shafts available?
Last Edit: Mar 17, 2023 13:36:00 GMT by HARDCORE
Mar 17, 2023 16:44:55 GMT
Hmmmm. How do these compare (strength-wise) to the Atlas? And is there a similar array of diffs and shafts available? Strength wise out the box a 8” or 9” bats an atlas out the park I’d say . There’s no need to strength the casing like you would do on and atlas no rally tax on parts either . and the shafts are strong but there’s tonnes of options to get diff shafts (strange engineering, hauser racing to name a few ) parts are available from the us pretty easily and most usual suppliers from the uk too . hope that helps ?
@hardcore
Mar 20, 2023 10:35:07 GMT
Yes, thank you. Any idea from what vehicle this one originated?
Mar 20, 2023 11:06:57 GMT
Hi sorry to say the axle has now sold .
Ford 8” rear axle Dez
@dez
Club Retro Rides Member 34
Mar 20, 2023 11:24:10 GMT
HARDCORE that was a mustang 2 axle. Only 8” or 9” that comes in that bolt pattern. It seems it might have been narrowed though, I thought they were 56.5” wide. The casings/shafts/brakes come up cheap cos no one really wants them as they’re different to a ‘normal’ 8”. Diff is same as all others, although 28 spline as all 9” are. It would be good for up to 300hp, and they’re significantly lighter than a 9” so good for smaller cars.
v8ian
Mar 20, 2023 12:02:29 GMT
IIRC add the correct perches and they fit under a Mk3 capri without issue, or was that Mustang2? Dez, Not so popular because they are 4stud?, and like you say are good axles, and better in my opinion because they are front loaders unlike the 2.8 axle, Did Rally Design not sell these from Curries to fit under a Mk2 escort?
Last Edit: Mar 20, 2023 12:04:08 GMT by v8ian
@dez
Mar 20, 2023 19:36:03 GMT
Ian yeah it’s cos they’re a ‘non-American’ pcd. And the brakes are unique to mustang 2, they’re only 9” diameter and have a unique offset/width. If it fits what you need as stock then they’re a good choice, but as soon as you want to change any of it you’re better starting with a different axle.
@hardcore
Mar 21, 2023 13:06:06 GMT
Thanks Gents!
Will need something strong (& narrow) at some point. No real rush but don't want to have to remortgage to buy an Atlas.
