Confused of Hastings here,
At present I am removing my Webers and going full Jenvey ITB set up, the setup was removed from a running grass tracker running an XE, comes with a pro made loom, and as, yet seems to be a doddle to fit, that is, until I get to the coil, the coil I'm running is the stock factory type with a 3 pin plug, However, the loom comes with a 4 pin plug, but only uses 3 pins ?? Obviously I can just go and buy 4 pin plug coil, but will it work,? the only thing I can think of, was the 4th pin run as a shield to stop interference?
