Hi All
I bought this Fiat 124 from Malta pre Brexit.
I wanted to turn it into look like a 131 Abarth but still be a 124 . I've been doing a lot of work on it as you will see in the pictures.
Yes it's a 2 door already ie b post moved back 4 inches. Steering has been converted to rack and pinion and also shell has been seam welded .Maybe I should list it this way
Rack and pinion conversion
Fuel filler deleted
Battery re located
Welded in roll cage
4 into 2 door
2 L Twin cam engine and 5 speed box
New floor pans
Seam welded
New front wings
New rear panel
New original Abarth exhaust.
Lada body kit .
New wire loom.
It has also been dipped (not chemical) to remove all paint etc.
Anymore work to do you're asking yes of course there is . A little bit on the nearside door at the bottom. It's at the stage of where I wanted to take it ie building it up to make sure everything fits ,take it all apart again dipped again and paint .
Everything that was taken of it is here .
Yes it's an unfinished project so difficult to put a price on it.If you have the same vision as me ( unlikely) the best thing is to come and look or speak to me .
Car is near Market Harborough.
Thanks for looking.
Finn
07983532136
Fuel filler deleted
Battery re located
Welded in roll cage
4 into 2 door
New floor pans
Seam welded
New front wings
New rear panel
Lada body kit .
New wire loom.
Thanks for looking.
Finn
07983532136
