What about the grit they use for blasting?
Crushed glass also comes to mind.
Interested to see where this goes as I also thought about this before.🙂
Davey
Resident Tyre Nerd.
Mar 11, 2024 10:24:25 GMT
Mar 11, 2024 13:22:04 GMT
Thank you for this link, I only want to remove rust off nut & bolts and some small tools that have gathered some rust,
I’ve been watching YouTube videos and hear (see) contrary opinions on what media to use to remove rust, some say to use plastic media and others say to use ceramic media and lots of other opinions in between, I’m going to make a few phone calls to suppliers and see what they have to say
I’ve not yet finished the build, I’m looking for suitable springs to isolate the bowl from the frame, I took these video clips a last night
This is without my temporary foam around the bowl
This is with my temporary foam, you can see the difference, so I need to find those springs, not yet sure if to use extracting springs or compression springs
Mar 11, 2024 16:46:26 GMT
Just got off the phone to Sand Blasters (https://www.sandblasters.co.uk) They recommended 4 by 10 (I think this is the size of 4mm x 10mm) ceramic media, so I bought 2 Kilos of it @£25.95 includes VAT and P&P, they said should be here by Wednesday, just going round looking for rusty nuts & bolts now
Mar 11, 2024 23:33:23 GMT
I finally found what I think will be a good spring to baffle the bowl, I found on Toolstation gate springs, those that push closed a gate if you leave it open These are around 250mm long so I bought 2 and will be cutting them in half and use them as feet for the bowl Now I’m off to the garage to make a start
Last Edit: Mar 12, 2024 7:14:33 GMT by mollydog1
qilin
I am interested to see how you get on with this. I have a large unit that was made in the USA. When I checked the model it was about $2,500 new. I got it second hand. When I switched it on in the house the noise was unbelievable and the vibration immense. I was like using an air operated demolition hammer. The cost of the media to fill it was around £200 so it was never used. There was a small selection of different types of media that were only samples. You can get steel shot for shot peening things like conrods. Media for fine polishing of gears etc. The larger the unit the more you can fit in but the cost of the media to fill it is much higher. It also has a feed for water which I believe works better on some media. Your unit is a good starting point.
joda
Mar 13, 2024 12:35:44 GMT
I done similar with a old sander and a plastic wash basin - i used Cat Litter to derust old nuts, bolts, washers etc it worked ok for what it was. I have since purchased a "Frost" tumbler - tho it was only £40 and two miles from the house, ive yet to use it. Frost also sell various fancy media www.frost.co.uk/vibratory-tumblers/
qilinTell me about the cost, two kilo’s delivery cost just over £25, if I tipped all the product in my small bowl it still wouldn’t fill it, two kilo’s might just half fill it I have a few old imperial spanners my late father gave me that have turned very rusty but they won’y fit in my bowl, I must go on a search for a more cost effective way of filling my bowl jodaI was also planning on using something like cat litter but thought for my first attempt, to see if it works best to use what was advised to remove rust, I phoned frost to buy the product but they closed at 4pm it was 4:15 when I phoned, so I phoned the next down on google search In my tests I discovered the method of attaching the bowl to the motor and frame wasn’t isolating the vibration from the frame and was making the whole thing jump all over the place, so I sat down and worked out another way to attach motor and bowl to the frame still using the four springs The method I’m using, I saw on a YouTube channel and that using a bolt (and washer) going through a rubber pipe inside the spring and as you tighten the bolt it compresses the rubber tube in to the voids in the spring keeping it tight and also isolating not all but the majority of the vibration from transferring to the frame I found a few rusty sockets and placed them in the tumbler, I only ran it for 90 minutes as it was getting late and I didn’t want to be upsetting my neighbours that late at night with the loud noise the thing makes. For sure I won’t be using this in the garage again as even with covering the bowl the dust was everywhere around the bowl After an hour and a half they looked like this I was told to file the bowl no more than just covering the items needing tumbling as the more product I placed in the bowl the more work the motor had to do This morning I placed the tumbler in the garden and will have it running for 3 or 4 hours and see what the sockets look like when I take them out
qilin
Mar 14, 2024 10:49:46 GMT
Very good, Near silent operation! My unit would have left that bench spotless. It might even reduce it to a flat pack. It is working as it should from what I can see. If you want to de-rust I would suggest citric acid mixed 9 parts water to one part citric acid. It will remove the rust from those items very quickly and cheaply. I use it for lots of parts and with heavier rust on them. The advantage of the vibrator is that it can give a polished finish. For the like of spanners I have used citric acid to de-rust, then polish with scotchbrite pad on a grinder and a mirror finish can be produced.
93fxdl
Enter your message here...
How about suspending it from a hook with bungy straps, with one to the side, preventing it winding up Ttfn Glenn
