Apr 19, 2024 13:22:33 GMT
A friend needs a battery charger to charge her motorhome and various other things from time to time, I said to make sure whatever charger she buys , to make sure it can charge a very flat battery (left lights on, totally flat for example) many modern chargers in my experience won't even recognise a battery being connected and won't start. Any recommendation for a charger (maybe 4 to 10 amps size) that will charge a flat battery? I have a proper old skool 1980s charger with an analogue ammeter but I doubt you can buy this type anymore. Ta
Apr 21, 2024 20:50:44 GMT
i think most chargers have a setting to just give out a low starting current for when the battery is well dead.
Apr 21, 2024 22:37:40 GMT
Old school transformer charger, usually picked up at boot sales for a couple of quid.
ferny
Club RR Member Number: 13
I've got this one now that the very old one from Aldi has died. www.halfords.com/motoring/battery-maintenance/battery-chargers/halfords-advanced-workshop-12a-smart-charger-191179.htmlI used to link two batteries together to trick the Aldi one into thinking a flat battery was greater than 6v... I'm 99% certain my new charger didn't need that effort the other week. I was rushing so didn't take too much notice. It might be a bit too pricey and have too many features for some though. If your friend has a camper but uses the single vehicle battery, investing in a leisure battery and split charge relay may be a better idea.
Last Edit: Apr 22, 2024 3:37:15 GMT by ferny
Apr 23, 2024 21:07:59 GMT
It has a leisure battery also. Yes thats another problem with 'smart' chargers, they try to auto select 6 volt.
Apr 24, 2024 19:30:18 GMT
Ctek chargers every time. Ctek
v8ian
Apr 24, 2024 20:47:57 GMT
What he says above ++++
jimi
I have a CTEK CT5, great charger/maintainer but it needs a minimum battery voltage of 2.0v or it won't start charging, AFAIK all CTECK's are the same.
