Hi I recently acquired a Merc 230CE, which is being resprayed in a candy, cobalt blue. Would like to lower the suspension by 3”, any ideas ref best springs & internal compressors, monoblock/ wire alloys to get ?? Many thanks
Your not going to lower one of those 3" without some heavy duty shocks like a Bilstein B8, 60mm H&R springs will actually drop it 80mm so will be close to what you want. Wheels will depend on what room you have left in the arch which wont be alot.
I use a Klan internal spring compressor, but there are Chineseum copies on ebay which will do the job.
I used vogtland springs with bilstein shocks, ended up cutting them quite a bit still. 3” is a lot for a 124 On the 16 from my Rabbit On 17” AMG
longman
Club RR Member Number: 3
Check what thickness spring shims are currently fitted , I lowered my SL quite a bit just by fitting a smaller shim , 1 pip on the front and 2 pip on the rear
Last Edit: Jul 10, 2024 6:37:17 GMT by longman
Paul 98 500 SL 86 911 Carrera/sold 23 Octavia Phev
