Feb 12, 2005 22:13:47 GMT
to the left, ladies and gentlemen,the full length spring.and to the right the 3 inch lowered one. ;D going to have to make a sump guard,cos when these are on the sumps gonna be about 2 inches of the tarmac ;D
lowering my benzBenzBoy
@benzboy
Club Retro Rides Member 7
Feb 12, 2005 22:17:06 GMT
Cool!! Where did you find the springs in the end? That's gonna look sooo sweet slammed ;D
Feb 12, 2005 22:25:19 GMT
got a phone number off datsfun.coil springs ltd (0114)2758573,company in sheffield.it cost £110 inc vat and postage to get them,which i didnt think was bad. trying to sort out a weekend when I'm not at work and theres someone to give me a hand. il get some before and after pics and post them when its done.
@benzboy
Feb 12, 2005 22:29:18 GMT
That's a good price! I might try them for a set of springs for the 115. I think that the springs require a special Mercedes tool to compress them, as the claws on normal spring compressors don't go between the coils.... I could be wrong as I havent worked on the W123 suspension before. There are other, more unorthodox methods though - ya just have to be a bit careful! ;D
Feb 12, 2005 22:42:32 GMT
had to do one for last years mot.what an on.it is possible to get normal type compressors on, tricky but possible. the chew on will be worth it though when i have a rolly and stand back and look at the finished article. il have to start saving up for tyres for the pentas now ;D
Feb 13, 2005 18:53:23 GMT
ill give u a hand next sunday bud , if u come help my pick up my engine on saturday, I'm sure itll all fit in the back of me carlton ;D ;D
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
Are they custom-made? If so how did you know what free length/spring rate to go for?
1972 Fiat 130 1985 Talbot Alpine 1974 Lancia Beta Saloon 1975 + 1986 Mazda 929 Koop + Wagon 1982 Fiat Argenta 2.0 iniezione elettronica 1977 Toyota Carina TA14 BEST CAR EVER!!!!!!!! 1979 Datsun B310 Sunny 4-dr 1984 Audi 200 Quattro Turbo 1983 Honda Accord 1.6 DX GONE1989 Alfa 75 2.0 TS Mr T says: TREAT YO MOTHER RIGHT!
Nah, easy peasy to lower a w123. Must have done 5 or 6 of the buggers now. What's all this buying new springs nonsense? Use a grinder - two and a half coils off the front, two coils on the rear - always cut from the top of the coil. Afternoons work. Slammed 123. Nice.
I used to use normal coil compressors, but be careful, as it gets a little tight under there.
Best way (in my humble experience) to get the front ones out is to put car on axle stands (safety first you understand) then pull coil in as far as safe with the comressors. With a trolley jack under and supporting the lower wishbone and almost taking weight of car, pop the lower ball joint, then very carefully lower the jack, until the spring falls out.
I cheat on the rears - just cut the lower bump stops off with a grinder (and weld it back on later), then drop the trailing arm down enough to pull coil out. No coil compressors are needed. You don't need to remove the driveshafts, but just undo the 13mm bolt on the centre of the hub, so the draftshaft can pull out a bit, allowing the trailing arm to push down further.
Loves a w123 on the floor...
Oh yeah, if you go v.low, make a sump guard, as the sump is cast ally, and it's pretty much an engine out job to replace it!
There is nothing more expensive than a cheap Mercedes
@benzboy
Feb 14, 2005 11:27:32 GMT
I cheat on the rears - just cut the lower bump stops off with a grinder (and weld it back on later), then drop the trailing arm down enough to pull coil out. No coil compressors are needed. You don't need to remove the driveshafts, but just undo the 13mm bolt on the centre of the hub, so the draftshaft can pull out a bit, allowing the trailing arm to push down further. Aha! I had the same trouble with my w115 - couldn't get the wishbone to drop far enough down. I think the set-up is pretty much the same as the W123, so I might try that! I don't mind the rake I have at the moment but sometimes I do get the feeling that the back end should come down to match the front.
