BLU
Apr 26, 2021 18:50:43 GMT
Wow!
I always love logging in and catching up on your thread. You're cracking on well with it. It'll look pretty impressive parked next to yours when it's finished.
The red tint on the rear lights makes such a big difference. #thedevilisinthedetail
Last Edit: Apr 26, 2021 18:51:00 GMT by BLU
The future's bright, the future's BLU
Silver 1987 MK2 Fiesta Ghia White 2006 MK6 Fiesta ST150 Yellow 2007 MK6 Fiesta Zetec S Anniversary #279 Green 2007 MK6 Fiesta Zetec S Celebration #471 (diesel conversion) Red 2008 MK6 Fiesta Zetec S Anniversary #893
Thanks BLU. Phil popped over last night as he has been away for a week, so was keen to see how it had progressed. He seemed pretty pleased with progress, so I gave him some homework of sanding all of the grill bars and awkward areas of the repaired half of the bonnet Sand,sand,sand,sand,sand.................. It's not quite there yet but a coat of primer shows where the bad bits are more easily. Also the epoxy primer is so hard it protects the filler from getting sanded when I apply the small skims required to get it the last 10%. Roof filler gets some primer; As does the bulkhead area, not looking too bad but lots of small areas need a little more work. Rear got some touches of primer over filled areas too as did the front grill. 165 hours
Apr 27, 2021 21:34:18 GMT
Bit of a night off tonight. Did a little when I got in from work and just added a little more filler just now. I flatted the primer back a little to remove the sheen (epoxy is a high satin finish) so the filler had a good key and skimmed in the areas that need it. Bulkhead; and roof; 166 hours
This really is going to be something special when it's finished, Can I ask please, is the epoxy primer 2k and, if so, is it possible to obtain as 1k ?? Thanks, Nigel
Apr 28, 2021 12:19:16 GMT
I'm enjoying the hour counter! I never counted how many hours went into any of mine and I don't think I've ever seen anyone actually log it on a project thread.
Apr 28, 2021 21:59:46 GMT
Alpina - yes it's 2 pack. No idea if you can get it as 1K. Johnny, I reckon I had about 30,000+ hours in my pop so I thought it would be interesting to log how long it actually takes to do stuff. Had a day off today so got a new bottle of gas from BOC and then me & mrs Blackpop went out for dinner in a restuarant!! First time since last November - was a bit chilly outside though! When we got back I had a good session in the garage. Not much to see photographically as it looks pretty well the same as before, the bulkhead has been rubbed down and had two more sessions of filler applied and rubbed down again. I think it's just about there now but we will see when this skim is flatted back. The rest of the session was spent sanding down all of the door shuts,inner window returns and stripping off the paint around the door edges. Window returns were treated with rust killer as they were a bit pitted. Then I moved on to the B posts where the rodshop had welded in new repair sections to both of them. He had done a good job and they were pretty flat, I needed to gently planish in a couple of high spots and then these got a skim of filler over them too. A post is looking good now its filled & primed. 171 hours.
vulgalour
Club RR Member Number: 146
Apr 28, 2021 23:36:41 GMT
Those door switch detents are one of my favourite bits of work on this so far, one of those 'invisible mods' because you couldn't imagine it not being there.
jonomisfit
Club RR Member Number: 49
This really is going to be something special when it's finished, Can I ask please, is the epoxy primer 2k and, if so, is it possible to obtain as 1k ?? Thanks, Nigel You can buy spray cans of epoxy primer. But as with all things the chemistry is probably different. The ones I've seen say 2k in a single can, so have something funky going on to prevent the reaction in the can. Epoxies are chemical reaction to cure not solvent evaporation. Epoxy and 2k acrylic etc paint are very different things though. The chemistry is very different as epoxies are often amine/ acid hardener vs isocyanate in the others. They have their own h&s considerations. This pop is looking great, and the work spot on.
Epoxy Doesn't have the toxicity of Isocyanate which always needs a fresh air supply, you can brush / roller it on with no precautions or spray it with a good filter type mask with similar risks to cellulose, personally I prefer a fresh air fed mask for everything as the best way to avoid getting anything on my lungs but the key thing is it won't poison you.
Thank you all for the replies, Useful to know, Nigel
logicaluk
This really is going to be something special when it's finished, Can I ask please, is the epoxy primer 2k and, if so, is it possible to obtain as 1k ?? Thanks, Nigel The one i bought is a 2 pack but doesn't have the nasty isowotsitnonsence in it. Dan
Apr 29, 2021 12:09:16 GMT
I have an air fed mask, but I mostly paint with 3M 06941 masks as I have an extractor fan built into the garage that shifts enormous amounts of air - it's so powerful it literally causes a wind past you.
Apr 29, 2021 22:38:29 GMT
Sand, sand,sand,sand,sand......add filler....... Pick a recent photo....it looks the same, lol.
173 hours.
75swb
Beta Tester
Club RR Member Number: 181
Apr 30, 2021 20:59:57 GMT
Nothing constructive to add but loving the read. Cracking work
You can buy spray cans of epoxy primer. But as with all things the chemistry is probably different. The ones I've seen say 2k in a single can, so have something funky going on to prevent the reaction in the can. We have some cans of spray 2K at work. They have like a breakable compartment inside with the second part inside it. You either plunge something into it to release the second part or one I saw you had to whack the can down really hard to break it. Then you have your normal 20-30 minutes to spray before the paint cures.
Last Edit: May 1, 2021 6:48:10 GMT by Jonny69
Today was a bit of a bust, spent most of the afternoon working on the daily (needed new rear pads) which decided one caliper would not wind back in. Ended up trawling the shops looking for a windback tool (there appears to be a national shortage of them) and eventually found Screwfix of all people had one. Even with the right tool it put up a fight, poxy thing. I won in the end though. So, not much happened on Phils car, as I only got a short time on it. Sand,sand,sand,sand, ..... filler...no! primer ooooh bulkhead is almost there now. 174.5 hours.
Nice job and great quality work. Your mate is very lucky with you spending so much time and doing a great job on his car Peter
Thanks Peter. Phil came over today and was nicely suprised to find his bulkhead all in primer Though it now has even more bits of filler back on it; Almost there now though. Phil carried on stripping the underside of the car (I give him the best jobs, lol) so that is now ready for rust treatment, primer and seam sealer. After that he started sanding the paint on the edges of the door jambs and around the window frames, finishing up stripping the paint off the inside of the other half of the bonnet. While phil was doing that I was sanding and filling...again, lol. The roof is getting closer to being right; And the rear arch flanges were filled so they will be smooth for the wings have a nice flat surface to bolt to. I've started on the B posts as well, even the door returns get filled so they will be perfectly flat. B posts are in the early stages here - I need to get the longboard on them to get them into a nice even curvature. The A posts are getting some major attention, the passenger side fits reasonably well to the inner wing, but the drivers side needs a fair bit of profiling and that big gap at the bottom will get addressed shortly with new metal. It's too tight at the top so that will also get dressed back for more even spacing. The gap that needs attention; 180 hours.
That bulkheads looking sharp......nice work....you certainly don't hang around. Dan
Opel Commodore A Coupe Opel Rekord C Coupe Opel Rekord C Saloon Vauxhall Magnum Coupe V8 (Magnumania) Mk1 Scirocco GLS Mk1 Scirocco GLS (early chrome bumper) Corrado G60 Mk1 Cortina 2 door Pre Airflow Mk2 Escort 1300 2 Door VW LT35 Tipper Truck BMW 320D E91 Tourer
That bulkheads looking sharp......nice work....you certainly don't hang around. Dan Don't tell him that, it's meant to look smooth!?
