markbognor
Club RR Member Number: 56
My laser cut acrylic projectsmarkbognor
@markbognor
Club Retro Rides Member 56
Oct 11, 2007 20:07:27 GMT
Reading Adam's last installment of his soap box thread reminded me about all the laser cut acrylic projects i've got. Lots are demo projects for kids, some are bits and peices I produced for uni projects and some were just for fun. Here's a couple of the latter, i'll get some pics of the other stuff at school tomorrow. Candle stick, Inspired by some candelabra of a simmilar design seen in a boutique in Brighton. The traditional shaped candlestick profile is etched onto each side of the clear 3mm acrylic, getting the two sides aligned was really hard. The profile was cut and the two parts are slotted together. The candle holder was turned from aluminium. Next is a pair of earings and a presentation box. Again from 3mm acrylic sheet, the box parts are cut and glued, the middle layer is removeable to get to access the earings. The centers of the earings were made from slivers of opaque 3mm sheet, cut on the laser then glued back together to form a striped sheet, that was then put back into the laser cutter to have circles cut from it. These striped circles were then pressed into aluminium tube. The faces were worksed smooth with progressive grades of wet'n'dry and then buffed. I should have used silver tube, but that would have been expensive and I had the ally there and then and wanted to crack on. These were both made for swmbo, some other stuff I have at school are a 3rd angle orthographic drawing teaching aid, pop art handbag, chess set + mini chess set, Rc car tyre gauge and scalextric startline gantry and lap counter. Pics to follow.
Last Edit: Oct 11, 2007 20:09:08 GMT by markbognor
Oct 11, 2007 20:14:06 GMT
I really can't wait to make some proper use of the laser cutter we have. ;D 'If you can draw it it can cut it'
markbognor
@markbognor
Oct 11, 2007 20:33:36 GMT
Its a really cracking tool to have in school because it is so fast, a basic project with some cuts and a little etching is done in ten mins, when on a basic cnc mill it would have taken half a day!
Last Edit: Oct 12, 2007 11:57:15 GMT by markbognor
The Doctor
Club RR Member Number: 48
Oct 11, 2007 22:03:02 GMT
I really can't wait to make some proper use of the laser cutter we have. ;D 'If you can draw it it can cut it' so if i send you a nice vector file from my inletmanifoldgasket you can make some flanges for me? ;D
I really can't wait to make some proper use of the laser cutter we have. ;D 'If you can draw it it can cut it' so if I send you a nice vector file from my inletmanifoldgasket you can make some flanges for me? ;D If you want it made of acrylic, mdf or 1mm ali ;D
markbognor
@markbognor
Thats a serious peice of kit your school has (unsurprisingly) Could you find out what wattage it is adam? our 25W wont touch Metal of any thickness.
markbognor
@markbognor
Oct 12, 2007 10:22:17 GMT
Some other bits: RC Car tyre diameter and width gauge. Sold a few of these. Handbag, example of how a resistant material can be used as a textile. God my figers hurt after putting all those split rings in! Bud Vase, example for an after school club mothers day project. Mini Chess Set, Based on the large chess set design but made more material friendly - its about 1/4 the size. Large chess set, CAD CAM project for uni - think i got close to 90% for that assignmet.
Oct 12, 2007 11:10:54 GMT
Those are awesome!!!!! specially the chess set, exzpect future PMs from me!!! I'm so bloody old skool, Wonky lines, accidents and junior hacksaws!!
markbognor
@markbognor
Oct 12, 2007 13:15:16 GMT
Here's a couple more bits: 3rd Angle othographic drawing teaching aid. The top layer is removable to place over the object (Y9 Cd rack project example 1/4 scale) With the veiw etched on the clear layer. This then folds flat and sits in the surround and on the base layer to show how the views open out into the drawing. Dimensions are etched onto the bottom layer so as not to confuse the views until they are layed out into the drawing. The scalextric gantry was another project for uni, electronics/programming this time. The product is a race stating and lap timing system using a picaxe programmable IC. I never got it working properly but the development and folder work got me a really good grade. I chose to make the gantry on the laser because it was such a quick method of manufacture.
Oct 12, 2007 15:38:03 GMT
I want to be a design/tech teacher...But I hate kids.
*n
tigran
In rust we trust. Amen.
Club RR Member Number: 142
My laser cut acrylic projectstigran
@tigran
Club Retro Rides Member 142
Oct 12, 2007 17:57:01 GMT
I want to be a design/tech teacher...But I hate kids. *n So did my long line of metalwork/woodwork/design teachers. Anyhoo cool 'stuff' dude. p.s. hope you cut the springs on the RC car before it got dropped ;D
Last Edit: Oct 12, 2007 17:57:35 GMT by tigran
moomin
Oct 12, 2007 18:52:07 GMT
some nice projects can't wait till i get my hands on the new laser cutter and the 3d router and the cnc lathe wh00p roll on term 3
@toxicknobs
Ether
Oct 16, 2007 14:16:01 GMT
Can you get etched plaques made up in acrylic, Mark...?
Ether
Etches glass, eh...
Hmmm...
Oct 17, 2007 11:18:08 GMT
'kinell, they give kids laser cutters these days! Whatever next, in my day it was all jumpers for goalposts. What size is your cutting table, if you don't mind my asking?
"Jeremy Clarkson, a man we motor enthusiasts need on our side like Lewis Hamilton's F1 car needs a towing ball and a Sprite Musketeer" My motor
markbognor
@markbognor
Oct 17, 2007 11:53:04 GMT
580mm x 400mm, the bed can be dropped around 150mm for etching on thick materials.
Oct 19, 2007 20:35:39 GMT
In my classroom weve got a novamill and a boxford CNC machine and a CAMM 2 milling machine with a CAMM 1 cutter/plotter. Wish I had a lazer cutter, they are so bloody useful!!! And a 3d printer (in an ideal world)!!! Dean
