Sept 28, 2008 22:38:49 GMT
WISH ID not started it now lol ,found more probs 2day playing gess work ,with the engine,its either sump hits the floor or rocker cover hits the bonett, or wacks the old mk1 wishbones then transfor hits steering then my twating manifold wont fit ,so in all had a curse word day lol,along with cutting driveshafts lol few pics had to make it fit best i cud considering clearance issuise ill get rack ripped of 2moz its going to be tight ,fitting inlet ,fan and rad in there and a incooler ,,,plus my dam manifold want fit ,so more chopping is needed lol once racked moved sorted ,ill cut tunnel to suit
Sept 30, 2008 18:38:46 GMT
just about to start on the other side and dam rain came ,grr
bit more this after steering rack off more tinkering to get prop in bit of driveshaft shorting
uwww, all that power and a welded drivershaft :lol: good luck mate, some quality fabbing skills so far though, very outside the box ;-)
just made a start on the short runner bit of bending here and there ,and it will fit ,
not mutch to add due a nice hangover from the night before lol ,so just tacked the short runner pipes up
few more bits done and started 2day welded pipes on short runner tinypic.com/view.php?pic=dff3x2&s=4,i need to angle it more ,ill sort this no probs trail fit of the propshaft those garden bricks come handy lol riped the old rear axle off, and oh dear dam std golf is short as well ,what a suprize then thought ill trail fit the rear 4motion axle ,and yes,,more stress ,i shorted it too mutch ,as i only tuck a outside measurement of the tyres ,forgot about the thickness ,,lol as u see from the rear wheel,looks ok thow ,so recut and welded a bit more on , seems better looks more like a skatbord then a caddy lol just riped carpets out ,to fit the clutch pedal looking as well as the propshaft will be up in the tunnel ,may have to partly mount the gear selector on the top
cant believe you are working outside onthis!!! my morris minor is outside andi havnt touched it for months!!! (mind you we get an average rainfall of 6 feet!!!) look forward to seing htis run! wonder how much quicker it will be that the pick up?
rotary turbo moggy traveller
Finlay
awsome !! lovin this thread
95 clio 16V - modded track/road car
95 clio Williams 2 - restored to standard
95 TVR Griff 500 - Taraka engine upgrade
MNR Vortx (kit car) - busa power
Chevette SR20 engine
MK2 Escort GM LS1
Chevette XE (building)
uwww, all that power and a welded drivershaft :lol: good luck mate, some quality fabbing skills so far though, very outside the box ;-) well lots are sketchy about this ,ive welded both of my driveshafts on the t5 bug ,and nev er head a problem ,,but i will be stick welding them ,as mig may look tidy but midsteel wire isnt recomended on drives over 150bhp ,but if u think about a 4wd caddy runing a minium of 400bhp that 100bhp per wheel ,,, ;D,,once there all welded right ill get them balanced ,,we don't wont things nipping here and there do we lol
cant believe you are working outside onthis!!! my morris minor is outside andi havnt touched it for months!!! (mind you we get an average rainfall of 6 feet!!!) look forward to seing htis run! wonder how much quicker it will be that the pick up? rain or snow ,,theres always a spare bit of time to do something bud,,i know it will be quicker unsure how mutch tbh ,but regards my bug ,there wont be a lot in it ,,,i just like to know silly ideas can be fittted...
decided to beef it up a little more well that ill do for that engine mount mount lol next 6spd linkage needs to be started as i mounted the propshaft right up in the tunnel , so remote will be welded best i can ,and i chop the cables to shortern them later,trail fit
Oct 12, 2008 19:53:33 GMT
few more bits done this after centre prop mount sorted just started on mounting the rear diff and axle prop too short lol so ill soon sort that little joby out,,
Ether
Oct 12, 2008 23:17:48 GMT
You're an absolute mental. Loving this
Oct 13, 2008 10:13:32 GMT
unbelievable skills + rotten shell + shedload of cool parts = Mental ride. I like it .
Social hand grenade. Does not play well with others.
Oct 13, 2008 21:14:35 GMT
not mutch to add untill i sort some steel 2moz ,, started to weld nuts in for rear mounts and decided i wont it lower ,stress lol ,ill re sort this 2moz only had a a bit of time as it were getting dark so made a quick restart on the short runner ,had to angle the box for the air flow ,which one day may be runing and found a stronger coilpack pack for better spark gaps 40,ooo ,instead of my 10,ooo one ,rough idea of how it will be wired lol
Oct 14, 2008 20:33:40 GMT
quick zip around for intake holes propshaft in bit of welding just mount the axle thought best beef the front up more ,we don't wont it dropping off now do we lol bolted up ive made this basic frame ,so i can move the rear axle in place were i need to weld ,so it will be sat approx 2.5 backwards shown in pic ,,then ill cut the prop to exstend it ,due to it been to short ,and be sorted afterwards diff just about bolted up ,,,
Oct 15, 2008 20:51:26 GMT
had to cut the track arms and a trail fit to get the rear wheel straight then trail fit the wheel as u can see its not central this is because the propshaft too too short at the mo , then u can see the main rear hub mount is hitting the inner sill ,a bit of chopping welding here and there ill sort that
just picked up a nice high flow red band holly feul pump,this may do the joby,,,
Oct 21, 2008 21:02:27 GMT
a little more here decided to chop the prop to algin the wheel base ,so i can centre the rear wheels,as now its bolted on a square subframe it makes things a tad easyer to move around erm i add a spare front prop i choped ,worked out good it fits perfect inside the rear one,,, ill weld that up when its light i don't want a flash lol rear track arms beefed up and welded ,,
