sierra suspension tat please.Dez
@dez
Club Retro Rides Member 34
Oct 24, 2008 18:54:06 GMT
some kind of adjustable/lowered struts. preferably oil filled not gas so i can pull em apart to weld coilover bits to them. discs that arent worn. front shoes. any front end poly bushes. RHS lower arm, joint is shagged on mine. standard steel X-member that isnt damaged.
07813289931 ddmetalworks@hotmail.com
full set of cossie shocks with cut spring sat in the garage if there any use bud?
Its not broken, its resting! Max signature image height: 80px
haggis
Oct 26, 2008 10:17:57 GMT
ive got koni fronts and bilstein backs, like new.
i removed them as i changed the car to forest set up
haggis
Oct 26, 2008 11:22:43 GMT
ive also got front end poly bushes left over from another project.
@dez
Oct 27, 2008 13:53:01 GMT
i thought cossie were different where they fit the hub? or is it where the hub fits to the lower arm balljoint? i cant remember. still, i don't know if they'd be of use to me.
haggis, PM me with prices please. are the konis gas or oil? i have no use for the bilsteins though as its all going on a p100.
