joe90
Yorkshire and The Humber
As the title says i am breaking 4 vans in total L a N reg 190 semi high roof P reg 190 High roof and M reg 100 long wheel base, semi high roof. All are diesel and all have power steering, 99% of parts are available, you can call me on 07917 666483 or leave a mesage or pm.
Thanks Bryan
joe90
BTTT
how much with postage for a o/s wing mirror the one with the blind spot glass at the bottom. also how much do you sell the di's with banana manifold and box for. thanks colin
joe90
Dec 11, 2008 20:41:05 GMT
how much with postage for a o/s wing mirror the one with the blind spot glass at the bottom. also how much do you sell the di's with banana manifold and box for. thanks colin Hi there mrcorty, About £18 for the mirror posted, i have a minter engine a box 150000 miles, i drove the van for 2 years and retired it due to rot. Is the engine for a transit or are you converting something else? ie do you need part of the prop pedal box ect, £275 for the engine a box complete with ancilaries but it does have a faulty starter. Thanks Bryan
Dec 11, 2008 21:39:34 GMT
sorted for the mirror now, will keep you in mind for the lump though as our F reg mk3 is slowly dyeing its got the early di with no pas
joe90
Dec 11, 2008 22:16:09 GMT
sorted for the mirror now, will keep you in mind for the lump though as our F reg mk3 is slowly dyeing its got the early di with no pas The van is getting scraped but the engine is coming out first, is your van a short or a long wheel base? if short you may be able to fit power steering from one of my vans if its long wheel base keep the king pins greased and put a couple of extra psi in the front tyres to make it a bit lighter on the steering.
Dec 12, 2008 10:16:45 GMT
its a stretched 190 recovery truck. steering is ok if car is sat level.
joe90
Dec 12, 2008 12:03:49 GMT
I have some odds and ends of mk3 bits as well and a mint set of mk4 seats if you need awt else give me a call on 07917 666483 or leave me a message
joe90
Dec 19, 2008 13:04:22 GMT
BUMP
