588X
May 23, 2004 21:09:20 GMT
Um, I'm not sure whats up with my Mk1 (gti golf) but I think I may have broken something. Obvioiusly I'll take it to a garage or a good mate but any idea what it is? Pulling away in 1st, going through all the gears even 5th and if I'm in reverse, it's not liking the initial pull away at all, it judders like f**k and sounds awful, then when you give it a fair bit of pedal it purrs like a kitten but getting there is pretty bad I do drive the of it, most of the time but at the same time, I do look after it - oil etc etc. The brakes are a bit dodgy and I'll get them sorted but otherwise it's a1. Any thoughts? Cheers Tan
May 23, 2004 22:00:20 GMT
sounds like you may have broke the clutch
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Sounds like clutch judder! Have you been over cooking the friction lining? Of course you have! ;D
This space available to rent. Reach literally dozens of people. Cheap rates!
588X
May 24, 2004 10:27:16 GMT
curse word curse word curse word someone mentioned a gear box mount , passenger side on another forum. So......... how much am I looking at if it is 1. gearbox 2. mount. I was stuck in London for hours, on and off the clutch, getting a bit impatient too
588X
May 24, 2004 10:41:58 GMT
I've no problem getting it into gear, going through them is easy, it judders and splutters for a while then when the speed is fairly decent it cruises lovely
