Volkswagen 1500 cc from a MK 1 Golf together with matching gearbox and starter motor. I haven't heard it run but was apprently running when removed from the car four years ago - £30
Hillman Hunter/variants front engine cross member, antiroll bar, suspension arms. - £20
Humber Sceptre/Superminx etc 4speed overdrive gearbox. No overdrive unit with it. Comes with bellhousing - £20
Alexander twin carb manifold and two SUs for Hillman minx/superminx cast-iron cylinder head engine - £30
Factory Twin Carb setup for Hunter and variants. Includes inlet and exhaust manifolds, twin strombergs and air cleaner assembly. £30
Four NOS aluminium rocker covers for Rootes 1725cc engines. These will polish up real nicely and without too much effort. £10 each.
1995 Jeep Cherokee electric drivers seat in beige leather. All electrics work fine. Small hole on seat bottom (hardly noticeable) and some ink marks on one bolster. £10
1995 Jeep Cherokee rear seatback with headrests. Beige leather. The top of the seat back has some scuffs on it but no tears. £5
Set of four 1995 Jeep Cherokee door cards - beige vinyl/leather. £5
Cylinder head from a 1997 Jeep 4.0L with rocker cover. Engine was running fine when I removed it. £10
Manifold gasket for Jeep 4.0L £2
All prices are for the part alone. Will calculate postage for each item upon request.
I'm Located in Chertsey Surrey - Junction 11 of the M25. Can deliver if you aren't too far away or you are welcome to pick up.
