I have Surplus to Requirements a Full Set of Vauxhall Carlton 3.0 GSi 12V Runnng gear from a 1989 Car.
We broke that car as the Shell was well rotten, but all of the Running gear was in perfectly good order, so we kept it hoping to use it at some point in a retro Vauxhall Project, but now as I have bought a V8 Bedford CF to work on, and the space is urgently required, I/we have decided to sell it on again.
There is ; - Complete Engine, (Getrag) 5 Speed G/Box, Propshaft, Complete Rear LSD Axle Assembly still in its Subframe, ECU, Airflow Meter, Airbox, Full front Suspension still in its cradle attached to the Engine, Radiator, etc, etc. There is basically everything to throw into a car of you choice and drive it !. There are recent new Brake Discs fitted back and front. The engine was running fine when removed around 18 Months ago, the Gearbox was nice and smooth, and there were no strange noises from the Axle/Diff, and everything has been kept inside, although obviously it is all sold without any kind of Guarantee or Warranty. There are no visible Oil Leaks from anywhere. It is all a little "Manky" through standing, so could do with a decent clean and freshen up before use. Grab yourself an absolute Bargain here, as I only want £150 for the lot !!.
It is collection only from the SY4 area of Shrewsbury. There is also a Forklift and Driver on site to assist with loading. Get in touch if you are interested, you should be at this price !!.
