Paul
Apr 30, 2009 12:58:11 GMT
I am in need of a k-series engine with loom, ecu, 5as and fobs but not fussed on the size of the engine as long as its a 16v.
Cash is waiting and I need it asap due to mine deciding to pee oil everywhere!
Last Edit: May 1, 2009 5:28:35 GMT by Oldbus
Paul
BTTT
try Les on BL Transverse, he might have something, 020 8654 3069
sooty
Try Phoenix Motorsport in Accrington. They do conversions on Lotus Elises, removing the 1.8 K series and replacing them with 2.0 Vtecs.
2016 Dodge Charger Scat Pack 2008 Jeep Liberty Limited
hi there i have just removed a 2lt k series engine from a coupe i think the loom is complete with ecu ect.. i am in south wales.. Gavin
hi there I have just removed a 2lt k series engine from a coupe I think the loom is complete with ecu ect.. I am in south wales.. Gavin they didnt do a 2.0 k series
sooty
hi there I have just removed a 2lt k series engine from a coupe I think the loom is complete with ecu ect.. I am in south wales.. Gavin they didnt do a 2.0 k series Isn't that the T series?
my mistake thought it was a k series
Paul
That sounds like the T-series turbo if its from a coupe which would be quite a tasty engine on its own...
it not a turbo was taken out to put a turbo lump in
Paul
It couldn't be a 2.0ltr or a T series then, must be a 1.6 k-series.
got an auto R reg 200 box is faulty can be heard running will check on eng size sun you can have all the bits plus eng £100 craig 07766634012 can you please contact asap as will be wieghed in mon if no reply
theres more to life than mpg & to much power is just enough.
