i'm attempting to do a conversion at the moment and i'm short of loads of parts that I didnt think about at the time
anyhow I need:
small form rover v8 starter motor or one that mounts its solenoid tight against the block
rover/lt77bellhousing
clutch slave cylinder
sd1 clutch plate and cover
p6/SD1 water pump
LDV 200 propshaft or a prop that has a lt77 universal joint on the end
dolomite sprint brake drums
sprint rear brake load sensing valve
i'm cool with abit of travelling here and there (although i'm stuck with getting lifts to places in other people cars due to aforementioned conversion ;D)
many thanks
(there will probably be loads more stuff to buy than that but cant quite remember)
anyhow I need:
p6/SD1 water pump
many thanks
