v8chevette
PROUD TO BE BEIGE!!
May 29, 2009 21:28:52 GMT
When i or others post a link from You tube using the tube button up there^^ all i can see is a blank square with a small red square, green circle and a blue triangle in the corner with the advert on the right and can't click on it to view the vid It's really bugging me now as i feel i'm missing some cool links, it must be something i've done this end as it's the same on other forums. Any help is much appreciated
rysz
May 29, 2009 21:54:12 GMT
What browser are you using? Also what anti virus software as merde like norton can be a bit overprotective to say the least!
Rysz.
v8chevette
PROUD TO BE BEIGE!!
May 31, 2009 19:04:38 GMT
All better now, i did a system restore and now all is well I must of pressed something i shouldn't
All better now, I did a system restore and now all is well I must of pressed something I shouldn't are you using windows 98? (an odd question, i know, but apparantly a new version of flash that utube has just started using will not work with '98. maybe other O/S's (other than xp and vista) have trouble too try clearing all your caches, and all temp. files then try again
Someone just shot the elephant in the room.
