stueyt
Saving cars from the scrapyard.
Aug 20, 2009 12:28:45 GMT
Hi All,
Anyone used one of these? Which is better the bumper attachment or hub attachment? Are they easy 1 man jobs? Does anyone actually own one of these and how much do they cost and would it be easy to knock one up myself.
I need to do some welding under the wife's Minor and would rather do it standing than laying on my back all day.
All help appreciated.
Cheers,
Stu.
Always looking for the next project!
v8ade
Aug 20, 2009 13:23:22 GMT
V8 on open headers at full throttle "Heaven"
Jaguar xf SportBrake rover 820 Turbo vitesse
luckygti
I need to try harder!
Aug 20, 2009 17:21:37 GMT
I don't have one, but have thought about it! I'd be inclined to go for the bumper mount as you don't need the axles fitted to roll it and I guess that's going to make life easier! Reckon making one yourself wouldn't be that hard, seen a couple made out of engine stands and a Minor isn't that heavy is it? Quick google image search for car rollover jig throws up a few...
Aug 20, 2009 17:46:38 GMT
Can't see the point of having axle ones, they're certainly very, very handy! Can you use the stand with the car complete, and how to you 'offer' the car to the stand. If you can do it with the car complete, I'm buying one!
Last Edit: Aug 20, 2009 17:47:35 GMT by DavidB
Aug 20, 2009 18:08:53 GMT
I built one out of scrap scaffold for my midget, best thing I've ever built.
stueyt
Aug 20, 2009 18:33:45 GMT
Car Rollover JigDeleted
@Deleted
Aug 20, 2009 19:03:33 GMT
I've never got round to making one for my own cars but they are pretty easy to do . if you make one make it with adjustable ends so it can fit a variety of cars bumper mounts or just make it with custom bumper mounts for each car .
rtlkyuubi
Low and Slow
Aug 20, 2009 19:18:30 GMT
Make sure you drain all fluids before you tip it over. You don't want oil dripping from the sump, past the piston rings and into the chamber as if enough gets in, you will hydraulic lock the engine when you come to start it again (which may cause permenent damage)
Aug 20, 2009 19:31:25 GMT
I'm just building one for my Plymouth, it seems to have taken way longer than anticipated partly due to the car being so flippin big and heavy but its a learning experience. It does a full 360° spin but is difficult to roll around on the casters , I'm just joining the ends to each other to make the whole thing stronger then it should be ok to wheel about and hopefully put on a trailer. Should be finished this weekend.
75 Range Rover 2 door 82 Range Rover 4 door 84 Range Rover 4 door 78 Datsun 120Y 2 door 78 Datsun 620 Pickup 81 Datsun Urvan E23 86 Datsun Vanette van 98 Electric Citroen Berlingo 00 Electric Peugeot Partner 02 Electric Citroen Berlingo 04 Berlingo Multispace petrol 07 Land Rover 130 15 Nissan E-NV200 15 Fiat Ducato
purplevanman
Way too orangey for crows
Aug 21, 2009 15:57:57 GMT
cant remember the name but there is one that can attach to bumper mounts while on the floor then you raise the car using a ratchet on the end of some threaded bar on the jigs. It will take a complete car, there are 2 or 3 different sizes, and you can buy mounts to suit each car.
Welder, fabricator, general resto work
purplevanman
Aug 21, 2009 17:05:18 GMT
Aug 21, 2009 17:58:48 GMT
I don't call that pricey, if it had been man enough to handle a ginormous yank tank I would have gladly bought it instead of wasting weeks building my own.
foxy99
I know this is an old thread but I always think it's better to add to an existing one than start a duplicate..
Anyway my question is: is it viable to make a jig to tip a car (Mondeo MkIII for example) which isn't just a bare shell?
EG you want to do welding on floors, replace brake pipes, exhausts etc comfortably on cars which need to be back on road within a few days.
Am thinking something that bolts onto front and rear hub on one side and you can tip full car with engine interior etc in it.
Problems I can see are massive weight of intact car, fluids spilling etc.
Better to just crawl around underneath banging head and cursing?
Last Edit: Jan 25, 2016 18:51:45 GMT by foxy99
Jan 25, 2016 10:39:41 GMT
I got one from here, it bolts to the bumper mounts, and they will sell you the mounts separately if you need to use it on a different vehicle. www.rolloverjigs.com/index.htmlYou just need to specify a vehicle when you order, additional mounts can be bought as & when needed
foxy99
Jan 25, 2016 18:53:29 GMT
Nice link, thanks.
Are they ok for fully-loaded cars or more suitable for bare shells?
Jan 25, 2016 19:51:08 GMT
foxy99
Jan 25, 2016 20:17:25 GMT
Coool. I've not clicked the link but they look expensive.
Wonder if that puts and strain on the suspension components on the opposite side...
@Deleted
Jan 25, 2016 20:26:16 GMT
One I made. Shed to garage to upside down under ten minutes
Jan 27, 2016 13:07:45 GMT
Nice link, thanks. Are they ok for fully-loaded cars or more suitable for bare shells? literally emailed them last week asking this, i bought one of their jigs about 4 years ago. (the entry level 165 quid ones) their answer was, pushing your luck, but we sell a heavy duty jig, or one for vans...
Last Edit: Jan 27, 2016 13:08:16 GMT by darrenh
Jan 27, 2016 15:37:04 GMT
You could always buy two engine stands and modify them -
