finally put my welder where my mouth is and am doing an mx5 powered project
ive got a complete car as a donor- I will be keeping engine, all ancillarles, loom, ecu, gearbox, prop, rad, complete front subframe, and maybe the rear one too.
THE HARDTOP HAS ALREADY GONE SO don't ASK.
if youre too stupid to read this I wont even bother replying to tell you I havent got it.
everything else is availalable. the car has a few nice bits on it, listed below, then its all stock stuff. these isnt a lot of interior in it as it was stripped for the track, but do ask as most of the dash/etc. is in the boot (black interior).
4 point proper rollcage, with large size baseplates (i think they're MSA spec) and inspection holes. gloss black powercoat. obviously stiffens the known flexy rear deck area more than pretty much anything else!!£100
polished stainless seatbelt turret brace, looks good and stiffens the back of the car in a known weakpoint. £80.
genuine mazda boot spoiler- the moulded-in one, not the one with legs. obviously much better qulity than a cheap repro and made out of a lighter material so the boot doesnt clonk you on the head £70.
adjustable front strutbrace, good quality with triangulated brackets, bright yellow. £75
RX7 FD alacantra seats, (which apparently only came in mazdaspeed cars, the others were cloth). a few marks, could do with a good clean as been sat around for a while, but no damage, £80
black leather momo steering wheel with boss and momo logo hornpush £40.
good black vynil hood, plastic window. no rips or splits, window is still reasonably clear too.£100
original genuine mazda floormats, black £20
the shell is totally rustfree. I welded in a new drivers side lower 1/4 inner and outer skin and arch lip myself for the previous owner, and its really really well done- its only got white primer over it at the mo, no filler, so you can see for yourself. just the panel to do this section was £100! no other rust or damage. £300 bare shell with V5c.
full set of 4 good locks (both doors, boot, ign) on one key, 2 keys supplied, £100.
full set of good used condition 1.8 brakes, 4 discs and calipers, hubs, £150.
front indicators mint £50pr del.
genuine mazda UK spec foglight switch. hard to find! £30
standard gearknob £10
uk MPH speedo 140mph £50 del.
side indicators £10 pr
rear lights mint £50pr del.
PAS steering rack £50
PAS steering pump + reservoir £40
doors, no rust or dents, with glass and electric window mech, no door cards or lock barrel, £50 ea
bonnet no dents £50
boot no dents £50
bumpers, good cond no dents, or splits, a few small scuffs, £50 each
rear spats/mudguards £20 del.
light motors £25 ea. del.
light mechs/frames with beam units and top plates £40 ea.
mesh grille £10
wings- one mint, one has a small dent right at front next to light(drivers), £50 ea.
drivers wing with some rust at bottom (repairable) £20
electric window switches £15
chrome interior bits- golfball trims, electric window switch panel trim, side airvent trims, £40 lot.
complete standard exhaust in good condition minus cat, £50
factory tint-top screen, perfect cond, £100.
car is in colchester and most bits can be posted.
bonnet no dents £50
boot no dents £50
mesh grille £10
