grant
May 28, 2010 14:38:54 GMT
When I switch my lap top on I am geting this message.... Its a fujitsu siemens, windows vista basic. Could anybody point me in the right direction how to reboot it or what ever it needs, I've looked on you tube but no joy
Last Edit: May 28, 2010 14:57:34 GMT by grant
Stu_B
Investing in rust!
May 28, 2010 14:40:49 GMT
You need a windows vista disc. And some pics of cars before this thread gets locked
May 28, 2010 14:41:19 GMT
Sorry.
May 28, 2010 14:42:32 GMT
Agreed, you need the disc, and tell it to do a startup repair.
May 28, 2010 14:43:31 GMT
"Media Test failure" and no OS sounds like a hard drive problem. It's either shagged or come unplugged. look on the bottom of the case for a cover about the size of a fag packet and pop it off to make sure the hard drive is plugged in properly.
grant
May 28, 2010 14:53:56 GMT
And some pics of cars before this thread gets locked Okay had a look threw my photobucket, heres my mahoosive ford sign with my mk2. Dam I don't have a disk.... Is this the hard drive, if so it was pluged in ok
May 28, 2010 15:11:44 GMT
grant
May 28, 2010 15:30:29 GMT
Lol catz make it all better ;D ;D
May 28, 2010 15:32:20 GMT
Its not retro, so I've shifted it in here. Hope someone can help you
May 28, 2010 15:37:16 GMT
Is this the hard drive, if so it was pluged in ok yep, thats the hard disk. Try plugging it back in and give the thing a go. Was it making any dodgy noises/did someone faff about with anything that caused it to not work?
May 28, 2010 15:38:29 GMT
Actually, it looks like it's trying to boot over the network or something. When it first comes on, press F2 and find the option for "enable network boot" and make sure it is disabled.
grant
May 28, 2010 15:45:31 GMT
Its working ;D, I pressed f12 and went down to sata, dunoo how long it will last, maybe new hard drive. But its alive ;D ;D Thank you for your help guys ;D
Last Edit: May 28, 2010 15:46:06 GMT by grant
rysz
May 28, 2010 17:05:12 GMT
That setting is not drive related, if you press the hotkey to get into the BIOS, there will be a Boot Order menu where you can take out the ones that you don't need (Like the network) and always have the first boot device as the hard disk.
Rysz.
May 28, 2010 20:16:14 GMT
Yeah, try DEL or F10 etc on boot to get to BIOS and change boot order to HD first.
My laptop failed recently as Vista half booted than battery died and could not find the COMMAND.COM. Fortunately I was able to USB boot into Linux and copy off anything good then let Windows do a repair and now works great. Also nice as lost a lot of those silly programs the wife added (Ikea kitchen designer) so now just the OS and Google Chrome.
