Dec 20, 2010 18:42:15 GMT
Has anyone added weight to the back of their car (assuming it's RWD) to increase traction?
I'm driving a volvo 740 and it's dreadful in the snow, braking and steering ok but awful getting going.
Dec 20, 2010 19:20:52 GMT
^nope but ive added 5 lumps of slate to the front of my imp (rear engined)
Dom
Limey
Dec 20, 2010 19:22:17 GMT
Drive like there is a full glass of water on the dashboard and u're trying to not spill any! Make that a pint and we'll all get through winter safely! ;D
Snow driving stylesstealthstylz
@stealthstylz
Club Retro Rides Member 174
Dec 20, 2010 19:35:02 GMT
RWD just point the front where you want it to go and steer with the throttle. FWD get a mate to push the handbrake button in, drill a hole through the handle/button and out the other side and put a roll pin/R clip through it so that the button is locked down. If the car slides at the front just gently apply the handbrake to bring the backend round. Need to keep the accerator gently applied too. Also learn to do a scandanavian flick, they're not just for gaining grip they scrub a lot of speed off too.
Paul try getting something to put under the rear tyres to get you off the drive.
Matt
Copey
Dec 20, 2010 19:44:41 GMT
FWD get a mate to push the handbrake button in, drill a hole through the handle/button and out the other side and put a roll pin/R clip through it so that the button is locked down. or just use some tape over the end ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Copey
Dec 20, 2010 19:45:40 GMT
Has anyone added weight to the back of their car (assuming it's RWD) to increase traction? I'm driving a volvo 740 and it's dreadful in the snow, braking and steering ok but awful getting going. i went to pick up a couple of bags of coal (20kg each) they are stayin in the boot til they are needed as they seem to help a bit
Dec 20, 2010 19:50:29 GMT
be weary of driving in high gears and low revs, you don't want to end up with a flat battery with having the electrics on, but the battery not charging
Dec 20, 2010 20:04:29 GMT
This conversation is making me laugh, really... A ton of old wives` tricks for driving with SUMMER tires in the snow, when the answer is obvious... ![;)](//storage.proboards.com/forum/images/smiley/wink.png) Winter tires are made for a reason! ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
@stealthstylz
Dec 20, 2010 20:05:09 GMT
FWD get a mate to push the handbrake button in, drill a hole through the handle/button and out the other side and put a roll pin/R clip through it so that the button is locked down. or just use some tape over the end ![;)](//storage.proboards.com/forum/images/smiley/wink.png) I've done that and hand it pop off which is not good when your thumb is nowhere near to disengage it. Matt
RetroMat
Column Shifting!
Dec 20, 2010 20:14:58 GMT
Been out in the saab, after reading this on the UKsaabs website: locking diff!, and it works very well indeed for getting unstuck! Should in theory work with anycar where the the handbrake is on the drive wheels? ![](http://i689.photobucket.com/albums/vv259/RetroMat/DSCF8252.jpg) ![](http://i689.photobucket.com/albums/vv259/RetroMat/DSCF8253.jpg) I purchased some part worn snow tyres and they are awesome, you can pretty much drive as normal - well slightly slower, longer gaps and trying to avoid other muppets on the road ![:P](//storage.proboards.com/forum/images/smiley/tongue.png)
Dec 20, 2010 20:52:01 GMT
Well I got the DAF out. The trick seemed to be to get the momentum going. This time I warmed the car thourighly so that it didn't hessitate and built up a bit of speed on the snowless parking space. That got it through the deep stuff. Oh my word was that fun. Its a bit twitchy on the back end so I may put a fat person on the back seat and let a little pressure out of the rear tyres.
Snow tyres are only any good when
1) They come in a size that fits your car which with mine if have a choice of bridgestone BF81 or bare rims.
2) Your local tyre fitter hasn't sold out
Dec 20, 2010 21:02:44 GMT
Faster. Faster. Until the thrill of speed overcomes the fear of death.
Dec 20, 2010 21:06:37 GMT
use first when coming up to junctions ie changed down from second and let the clutch up (gently) - just means you can stay off the brakes that little bit longer!
"Mechanical Power Subduing Animal Speed" (Robert Trevithick, 1808)
'72 BMW 2000 Touring '99 TT 180 (mrs) '72 BMW 2500
Dec 20, 2010 21:07:51 GMT
Without grip on the front wheels, you`d get to about the 5th or 4th pic, and then keep on going straight ahead ;D mytyres.co.uk had 165\80-13`s, i don't know if thats too big for your Daf Pauldaf? ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Is it on 12" wheels or smaller?
Dec 20, 2010 21:09:42 GMT
too small in fact Rims are 135mm by 14inchs
Triumph runs 155 by 13s but thats front wheel drive and dissolves at the very sight of salt ;D
Last Edit: Dec 20, 2010 21:11:31 GMT by pauldaf44
Dec 20, 2010 23:42:43 GMT
hehe, i can imagine ;D Hankook has 155\55-14 tyres, but a little pricey at 66 per corner...
Dec 20, 2010 23:44:36 GMT
if you've got holes or spokes in your wheels you can use rope as a make shift snow chain, tie it to a spoke, run it round the tyre and in from the other side in a zig zag all round the wheel.
You HAVE to make sure theres clearance all round the rim so the rope wont catch on anything and you have to keep an eye on it, if it wears through and starts flapping about it could pull a brake line off or yank the handbrake on.
couple of bits of rope are easy to chuck in the boot though and could get you unstuck enough to save a long walk.
conrad
Here to fix your cabin.......
This conversation is making me laugh, really... A ton of old wives` tricks for driving with SUMMER tires in the snow, when the answer is obvious... ![;)](//storage.proboards.com/forum/images/smiley/wink.png) Winter tires are made for a reason! ![:D](//storage.proboards.com/forum/images/smiley/grin.png) I would like to nominate you as the official person to come to Ireland, where i am (and people are coping extremely badly with the snow even though we've got far less than britain), and tell everyone to stop being such idiots, get proper tyres, LEARN HOW TO DRIVE, and stop freaking out, it's only snow
This conversation is making me laugh, really... A ton of old wives` tricks for driving with SUMMER tires in the snow, when the answer is obvious... ![;)](//storage.proboards.com/forum/images/smiley/wink.png) Winter tires are made for a reason! ![:D](//storage.proboards.com/forum/images/smiley/grin.png) I would like to nominate you as the official person to come to Ireland, where I am (and people are coping extremely badly with the snow even though we've got far less than britain), and tell everyone to stop being such idiots, get proper tyres, LEARN HOW TO DRIVE, and stop freaking out, it's only snow Haha, i`m sure i could give it a go, just need to bring some snow tires and get a RWD car ;D My english neighbour is not amused by the slippery roads, haha
Dec 21, 2010 11:19:57 GMT
I fitted these to the Imp and its awesome!! ![](http://i241.photobucket.com/albums/ff81/gurnsimps/snowyimp3.jpg) Got caught in the heavy snow yesterday but no problem at all,even passed a 4wd vitara floundering on a steep hill in our village!! ![](http://i241.photobucket.com/albums/ff81/gurnsimps/impsnowy.jpg) slow and steady is the way to go although I must admit to having a play on the wide open stuff and the imp is soooo controllable with the rb1's ;D ;D
