10mpg
Club RR Member Number: 204
As above really, been moshing the ideas around this year as to what to build this christmas when things should be very different than they are now for me pricing up a Sunday afternoon hooner/hilclimber/track day toy, and this idea is the flavour of the month. Probably M52 single vanos lump on megagsquirt (would the BMW management be able to run things) 325 manifold ect ect i'm thinking thsi engine would be the best bang for buck, and least weight penalty? Would it even fit without throwing the weight all over the nose? would it be so tight in there that trackside repairs become impossible (been there hated it..) Would also be interested in what back axle will fit to take the grunt (assuming E30?) and what are my options for suspension brakes, hoping to keep as much parts bin stuff as possible, budget is reasonable but not mental.. Car will be stripped repainted painted braced caged and perspex/buckets..
Mar 26, 2012 14:56:04 GMT
Mar 26, 2012 18:41:22 GMT
I've got a running E46 328 for breaking if you want an engine box and drive train. Pm me of you're interested
andyborris
Mar 26, 2012 19:52:35 GMT
Last Edit: Mar 26, 2012 19:53:40 GMT by andyborris
10mpg
Mar 26, 2012 23:56:09 GMT
WOW cheers dudes exactly what i was looking for, I'll have a good read up tomorrow...
Thanks for the offer Adam, not in the market for one yet as i have to source the e21 first and that's the hard bit! well finding a solid 2 door is anyway!
Speak to Rob0r on here !!
yeah, rob0r has done it., and ive worked on the car. its horrendously tight on space, but it does go. he recons the e21 diff and shafts aint up to the power though, he was talking about changing his.
rob0r
East of England
Club RR Member Number: 104
Mar 27, 2012 12:41:02 GMT
As above really, been moshing the ideas around this year as to what to build this christmas when things should be very different than they are now for me pricing up a Sunday afternoon hooner/hilclimber/track day toy, and this idea is the flavour of the month. Probably M52 single vanos lump on megagsquirt (would the BMW management be able to run things) 325 manifold ect ect i'm thinking thsi engine would be the best bang for buck, and least weight penalty? Would it even fit without throwing the weight all over the nose? would it be so tight in there that trackside repairs become impossible (been there hated it..) Would also be interested in what back axle will fit to take the grunt (assuming E30?) and what are my options for suspension brakes, hoping to keep as much parts bin stuff as possible, budget is reasonable but not mental.. Car will be stripped repainted painted braced caged and perspex/buckets.. Why hello there ;D. As mentioned this is something I've heavily been involved with over the last few years, I have a suspicion I may have been the first to get an M5* engine mounted in a RHD E21 shell. I've only dealt with the iron block M50B25 non vanos engine but the swap is identical. M5* engines use identical dimensioned bottom ends to the M20 engines (found in the 320/323i cars), but they are supposed to be laid at a flatter towards the driver's side. The result being you can use the E21 engine mounts that sit the M5* at the same angle as the M20 (more vertically), the beauty is that from the bell housing backwards it can be all standard E21 M20 parts (gearbox/prop). No custom gear linkages or custom length props ;D. The other win is that the engine now clears the brake servo perfectly. There are two downsides to this, 1) the M50 sump now hangs dangerously below the subframe (custom sump needed), 2) the standard inlet rubber elbow to the MAF won't clear the passenger wing (Samco 90 degree elbow or cut away the inner wing). I tried to mount the M50 at it's designed angle but I found it was impossible to get any sort of rear exhaust manifold to clear the steering linkage. A quick recipe based on my own: M50/M52 engine M20 brown temp sender (for the gauge in the instrument cluster) E34 M50 sump, modified, cut and winged to gain clearance E21 M20 metal engine mounts (rubber ones of your choosing, I'm using hockey pucks) E21 M20 subframe E21 M20 gearbox M20 flywheel of your choosing (E21 M20 is apparently the lightest OEM and what I recommend) M20 clutch of your choosing E21 M20 prop E36 328i tubular exhaust manifolds (E36 323i might be the same), these need very slight modification Front mounted electric fan E36 328i radiator with custom mounts or Nas80 spec rally rad Custom exhaust system (you could use a 323i system but don't, they are tiny and VERY heavy) Nas80 is the guy to speak to about getting the sump modified as he has got a very good deal for this with an engineer he knows. He can also spec you a nice rally spec radiator for this conversion too, but I've found the E36 radiator as worked well enough. He is also able to do the whole conversion for you for a price! The exhaust manifold clearance is still fairly tight, sometimes it binds against the steering linkage guibo. I'm swapping mine out for a straight linkage in the coming months. You don't have to run the engine on megasquirt. My M50 non vanos is running the standard engine management. For M52s it is slightly more complicated. For a start they have EWS immobiliser security, if you retain all the EWS sensors and ECUs from the donor then it's no problem. But a lot of people get the ECU flashed to remove the EWS. The show stopper though is the M52 ECU needs a speed pulse signal from the ABS sensors, this limits the ECU to 4-5K RPM if it can't find this signal. But the reflashes available remove this feature too, as well as tuning it up a bit. Speak to Nas80 or Danthe on E30zone. I'm running the pig iron M50 and it's not that front heavy at all. The M52 is alu blocked and should be significantly lighter than the original M20 engine. Not really something to be concerned about. If a cheap enough M52 2.8 came along, I'd snap it up just for the additional lightness. Access to the engine bay is not that bad and certainely nothing to be worried about. I will admit getting access to underneath the inlet manifold is a right b!tch. The only times I've needed to get under there though is anything related to the starter motor, air hoses/ICV, temp sender etc, so nothing you will need to touch on a track day. Back axle... It really depends on what you want to do with the car. It's well known that people have exploded diffs and broken driveshaft CVs when running higher power, but I haven't heard of anyone for a while that's done this, apart from myself. I blew a driveshaft CV launching in first gear, very unsmoothly. I'm also running a welded diff, the other guy I knew (Murran) who blew more than one driveshaft was also running a welder. Me and a mate have a theory that the welded diff is more likely to break shafts than open/LSDs as there is obviously more stress on the drivetrain. I have spent a lot of time researching different rear axles and a fair amount of people have done this. You can buy off the shelf E12 diff conversions from Fritz Bitz (£££), or custom mount other stronger diffs into the original axle. Others have mounted complete E28 axles (5 stud) and I have looked into doing the E30 axle myself. E12 conversion use the E21 driveshafts, they IMO are the weakest link in the whole transmission! E28 axle swap increase the track massively and require bubble arches, you may find solid mounting is the easiest way. E30 axle will increase the track slightly, but the deal breaker for me was losing the original petrol tanks. I have actually mocked this up on a scrap shell. I'm also scared of screwing up the rear axle alignment if my measurements/cuts/welds are out causing dangerous handling. I'm not happy with any of the axle solutions so I'm going to be using my car with the standard axle with the welder and take it easy at low speeds. If and when I have the money, I will custom mount an E30 medium case diff into my E21 rear subframe and then buy custom strong driveshafts to match, but this will be in the region of £700 for the driveshafts alone. Brakes, use 323i stuff (vented front discs and rear discs) and if you feel they aren't adequate then upgrade. Suspension, the easiest thing to do is send off some 323i struts off to Gaz for £1000 (I think). My coilovers cost less than half of that but are strictly DIY. Also consider polybushing the whole car. Any more questions then fire away... I'm sure MIB will chip in at any minute now, and Nas will likely have something to say also. The www.bmwe21.net/forum is also very good for information. My 323i M50 retrorides.proboards.com/index.cgi?board=readersrides&action=display&thread=71185&page=1Mine and Nas's M50'd E21s Can be much tidier than this!
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
rob0r
East of England
Mar 27, 2012 13:18:00 GMT
One more thing, most of the time spent on my 323i M50 was getting it welded up... Either get a straight car or be prepared! Check front footwells, chassis rails, rear inner well arch, behind rear seat, boot floor, front panel, sills, everywhere pretty much!
Mar 27, 2012 16:58:51 GMT
I'm sticking a M52 into a Triumph 2000 MK1 at the mo' With all due respect to e21s & e30s, I want the link for the thread for that! Sweet!
andyborris
Mar 27, 2012 18:48:52 GMT
You'll need to get the E30 flywheel shaved or take a grinder to the M52 sump, DanThe is the "go to" for a flywheel, unless you stick with a dual mass thing!
And be careful when using E36 gearboxes, very low gearing, OK if you love wheelspin!
rob0r
East of England
Mar 27, 2012 19:35:19 GMT
Just to add, my E21 flywheel didn't need shaving and if possible I would stick with the E21 M20 gearbox if possible, anything else will be custom work.
10mpg
Great stuff Rob, cant thak you enough! I'm pretty sold on the idea now, will start hunting for a base car once i get back from the states, pretty sold on the M52 as well, given the use i want the added lightness appeals and i run a lightly tuned one in my e36 vert and i loves it! I wont be running a welded diff, i'm just not a fan and it doesnt suit my 'road' driving style, however an LSD is pretty much essential, so I'll have to look into that, This image sells it for me, I love the look of a smallish good looking car crammed full of engine! My plan is for something fairly tidy, in a 'tracky' sort of colour, maybe orange..? road legal racer rather than everyday car, so i have to find a solid base car that is cosmetically challenged enough for me to not restore, (i'm a sucker for making cars 'original' if i feel sorry for them)
Tbh I've owned a 328i for a number of years and it's a nice motor but fragile compared to the 325i lump (or m52/50 for the purists) and I'd miss out the m52 unless you can be certain of it's history,I'd drive the car round for a few hours first to check it's not overheating as that's what killed mine,a lack of maintenance (my own fault) but now I'm putting a m50 in as I know it won't break,well it's had no issues since I bought it in january,been to gatwick and back twice,gets used everyday,had it stuck in m4 traffic for a solid hour of not moving very far and it never went over 1/2 way on the temp gauge. Much better motor IMO.
