adam73bgt
Club RR Member Number: 58
Hi, So basically the car's been working fine for a while now, but when it came to starting it today, it wouldn't start. Theres power coming from the battery so thats fine, but all I can hear is a click from under the bonnet, no turning over or anything So does this mean my starter is fubar? is there anything I can check? The car is an MGBGT Any help is very appreciated as I use the car daily so cant really afford to not have it working Thanks
Last Edit: May 2, 2013 11:14:24 GMT by adam73bgt
Apr 19, 2013 12:48:23 GMT
Could still be the battery, how have you tested this? You can have 12v but not enough amps if its going a bit wobbly. First thing I'd do is try and jump start it from another car - if that works take the battery off and charge it overnight. If it still clicks when trying to jump start then it could be the starter solenoid or as you say the starter itself.
Apr 19, 2013 12:59:54 GMT
Its a B with a pre-engaged starter ie solenoid on the motor? Or one with an inertia starter motor and a separate solenoid?
Can you turn the engine over by hand (with a socket on the crank nut)? Or maybe try rocking the car while it is in gear. I'd have thought the most likely culprit was the stater motor.
Apr 19, 2013 13:02:55 GMT
sticking starter solenoid or a poor earth from the engine block to the body
stick it in gear, switch on ignition. then try gain out of gear. sometimes its enough to unstick it
dgo
Apr 19, 2013 13:09:12 GMT
Old BL trick:
Tap the starter firmly with something insulated (e.g the long handle of a sledge hammer or similar - not too hard though!). Can be as simple as worn brushes sticking and not making contact inside the starter. If that's the solution change the brushes in the starter
adam73bgt
Apr 19, 2013 13:51:34 GMT
Tried jumping it but had no effect
The starter is the later pre-engaged type i believe
will try rocking it on starter and see if that helps at all, may give it a bit of a tap too
adam73bgt
Apr 19, 2013 14:03:51 GMT
Well ive tried the ignition with it in gear and ive tried rocking it by hand while in gear, also gave the starter a few firm taps and it doesnt seem to have done much :/
Apr 19, 2013 14:33:55 GMT
Take the starter out, unbolt all connections, clean them and then bolt it all back in. I did this after having the same fault on my Beetle starter and it has worked perfectly ever since! I didn't believe that the connections could get that bad seemingly overnight, but I have no other explanation for how I fixed it. You may as well clean up the battery terminals while you're at it too.
rodney
Apr 19, 2013 22:55:12 GMT
push start it to move it , but just get a new starter , or try bridging the solonoid to see if its starter,.
adam73bgt
Apr 19, 2013 23:35:18 GMT
Pretty much resigned it to be a duff starter, gonna get one and give it a shot, looks pretty simple to change over
Apr 19, 2013 23:40:00 GMT
Check that the ignition switch is returning to the IGN position, had a couple of cars where it's left the starter engaged with the engine running and its burnt out very quickly.
adam73bgt
Apr 19, 2013 23:51:54 GMT
I'm pretty sure the ignition switch is ok, it seems to work like it usually does at least..
It's doing nothing at all? Does your car have any history of having a clutch change? It could be as simple as a broken terminal (easily damaged when changing a clutch IME by many).
If it does turn out to be the ignition switch I do have a spare (new) item lying around for your model of car (I may have broken a 'B with a friend of mine many years ago of that vintage;)).
Last Edit: Apr 20, 2013 1:43:20 GMT by ChasR
adam73bgt
Nothing except for a click sound, which i assume is the starter solenoid throwing out? ive got no history of a clutch change in the paperwork ive got which covers it back to about 2007 or so, i will have a good look at the wires at the starter to see if anything is amiss, had a clean up of a few of the terminals up top in the engine bay today
Last Edit: Apr 20, 2013 1:46:45 GMT by ChasR
adam73bgt
isnt the starter relay the little block on the inner wing just behind the fusebox? thats what my book of mgb electrics called it anyway The battery connections have been a problem in the past but they've been sorted now, so I'm pretty confident its not them, the engine earth is a bit frayed so ill be looking to replace that soon anyway, might give changing it a try before changing starters, not sure entirely on the voltage at the battery but its pretty new and when we put a jump pack on the battery it made no difference, so i don't think starting ampage is the issue.
adam73bgt
Apr 20, 2013 10:33:57 GMT
Right so ive got the starter off I'm thinking i should try testing it to see if it'll spin at all, so how would i go about testing this? put a 12v feed onto the bottom stud where the feed from the battery was? and then an earth coming from the body of the starter?
Apr 20, 2013 14:10:36 GMT
Pretty much it and a feed going into the solenoid that you can remove quickly . Just be a little careful that you do not short out the battery and be aware that starter motors without any form of support (a vice would do) can move about quite a bit.
adam73bgt
Apr 26, 2013 10:41:53 GMT
Well heres an update, fitted a new secondhand starter and the engine turns over but it wont fire at all Can hear clicking from the fuel pump on turning on the ignition so i think its got fuel So my thinking is it must be something in the ignition circuit thats gone wrong, but everything seems to be connected up, only thing ive altered in the ignition circuit is moving the earth from the dizzy to the body because it was extremely frayed Any ideas? thanks in advance
Apr 26, 2013 14:02:26 GMT
Did they have electric pumps?
Either way pull the fuel line off going to the carb to ensure there's actually petrol getting there to rule that out.
Check your coil connections and if possible take a spark plug out,hold it on the lead with insulated pliers near the engine block,get a mate to crank it to see if your getting spark then that's that ruled out.
My guess is your missing one of the above.
