toast
Apr 21, 2013 14:27:42 GMT
Hi, want to get my Vanette low but trying to work out how is being abit of a problem. Rears are fine, just put them on blocks and I'm away. Its the fronts I'm having problems with, its on a transverse leaf spring. Anyone got any ideas?
v8ian
Apr 21, 2013 15:32:38 GMT
I can only think of 2 options without seeing the way its set up,
1, Raise the centre spring perch, or 2, Get the spring de arched
Apr 21, 2013 17:28:30 GMT
Or raise the crossmember.
R.S. Autotech. Servicing/Repairs/Diagnostics.
toast
Apr 22, 2013 15:49:54 GMT
People have told me about flattening the spring, this is all well and good but surly it wouldn't fit again as it would be longer (if I'm making sense) can anyone clarify?
Kev
Apr 23, 2013 14:33:03 GMT
It will fit but cause negative camber
Apr 23, 2013 15:24:06 GMT
The spring won't be any longer, it will just be straighter. The wishbones move in an arc so as they move up the outer most point also moves out, untill they are at 90 degrees to vertical, then they start to move back in. when the wishbones are at 90 degrees your spring will be dead flat. hope this makes sense.
