Right
As part of my bongo wheel wobble issues been looking at replacement wheels should mine be borked - or if i need to centre the existing ones to isolate that as an issue...
If i needed to take a spigot of 67.1 up to a 70mm CB alloy, these would need to be 1.45mm thick ring of metal (is this even feasible for a spigot ring?)
What sort of tlerance do you generally need to work to so that you can centre the wheels whilst still actually being able to fit the ring to the hub and then fit the wheel?
Cheers
Tim
Cheers
Tim
