As I am changing the rear suspension setup on my car,
I am in need of some replacement springs for the rear
struts. The new springs although for the rear of the
car will need to be as strong as those for the front
of a car, this is due to the car being fitted with an
LPG tank in the spare wheel well. And the space saver
spare wheel being replaced with a full sized wheel as
a spare. Add the fact the car is fitted with a towbar,
she will be used as a real work horse!
So the springs will need to be strong enough to support
this and not bottom out at the slightest bump in the
road.
Picture of new strut with old one and the upper strut
mount so you know what type of springs with the right
or similar ends to suggest.
Here are some measurements made before my back went so
I won't be going near the car for a few days!
To get the car sills level with the ground with a
distance of 7 inches (17.8 cm)
The spring was compressed to 7 inches (17.8 cm) between
the metal plate of the strut and the top of the upper
strut mount.
When the car was jacked up with the wheels off the ground
the distance between the metal plate of the strut and the
top of the upper strut mount was 9.5 inches (24.1cm).
So springs either for the rear of a larger heavier car or
from the front of a small/medium car
I was thinking front springs off a mk6-7 escort or front
springs off a 307 pug(02) but can't get measurements or
specs on the web
So info and possible alternatives please.
road.
strut mount.
specs on the web
