Fungus
Looks promising!
Any mods planned or just a nice standard restoration? let me know if you need parts.
Looks promising! Any mods planned or just a nice standard restoration? let me know if you need parts. Just a standard restoration, upping to 12V though. what things did you replace in your wiring loom, doesn't look like there needs many things replacing (apart from bulbs)
Fungus
I built mine from scratch.
You'll need to replace all the bulbs, the coil and the rectifier, the stator plate and the battery.
Your bike will just have a little rectifier diode on with a sleeved red wire that goes to the battery (this converts the current to D.C to charge the battery).
You could probably get away with converting without changing the stator plate and coil , see how it goes. I have a 12 stator if you need one though.
I take it you know about David Silver spares?
I take it you know about David Silver spares? yeah, i've already ordered some things off there
I built mine from scratch. You'll need to replace all the bulbs, the coil and the rectifier, the stator plate and the battery. Your bike will just have a little rectifier diode on with a sleeved red wire that goes to the battery (this converts the current to D.C to charge the battery). You could probably get away with converting without changing the stator plate and coil , see how it goes. I have a 12 stator if you need one though. i looked from when they first introduced 12v to the bike and its the same stator so i think i'll be fine with that. Thanks though, just wanted to make sure
I've ran into a little problem. my rectifier has 2 pins, whereas all the 12v ones i come across have 4 pins. any solutions will be greatly appreciated
Nice to see another early 80s CG125 on here
I've ran into a little problem. my rectifier has 2 pins, whereas all the 12v ones i come across have 4 pins. any solutions will be greatly appreciated How many yellow wires from the stator plate?
I've ran into a little problem. my rectifier has 2 pins, whereas all the 12v ones i come across have 4 pins. any solutions will be greatly appreciated How many yellow wires from the stator plate? One
Davenger
It's only metal
Club RR Member Number: 140
'80 Honda CG125 RestorationDavenger
@dminifreak
Club Retro Rides Member 140
Ah the K1 CG125 Should never have sold mine, great little bike. I got loads of bits from David Silver too. His replacement seats are brilliant
What wire colours do you have coming out of the rectifer? Are you sure it is a rectifier/ regulator and not just a rectifier. Reg/ Rec will run a DC system with a battery, a rectifier will run an AC system without a battery (and only has 2 connections)
one white and one red/white. it is just a silicon rectifier, so does that mean that i can get away with not changing it? obviously i'l still get the new 12v battery, ignition coil and bulbs ect. thanky you for your help by the way
Aug 13, 2014 10:06:00 GMT
hi new to the seen but i am looking for help converting a 78 k1 to 12v aswell as customising a few things. any help with the specifics on what needs replacing would be grand. cheers.
