Jul 11, 2014 18:00:10 GMT
Thanks for all the help again, guys. Just read through some of that thread about the Golf on the Renault wheels: "Renault scenic ones 16x6.5, with 165/40s with some big spacers on the back as they're et 49" According the bloke who owns the car. They'll cost me a mint, won't they? (How much does a set go for with tyres - I could only find single wheels on ebay) Will I need to buy longer bolts to get them to fit, if I buy spacers? (Don't worry, I've just bought the oil, so I can crack on with the service, first!) Oh, and Euro Car Parts have got another 50% off sale
adam73bgt
Club RR Member Number: 58
Jul 11, 2014 18:06:23 GMT
The 16inch scenic steels seem to go for 50 quid each on ebay with tyre, I'm sure you could probably get a set cheaper if you went down a scrappy or something Longer bolts tend to depend on how long the original bolts are and how much you're spacing out by I think, though I'm not an expert on the matter, I've got bolt on spacers which removes the issue
Jul 11, 2014 19:08:10 GMT
The 16inch scenic steels seem to go for 50 quid each on ebay with tyre, I'm sure you could probably get a set cheaper if you went down a scrappy or something Longer bolts tend to depend on how long the original bolts are and how much you're spacing out by I think, though I'm not an expert on the matter, I've got bolt on spacers which removes the issue Shame I cant swap my Hyundai i20 steels (less then 2000 miles on them - "5.5 x 15 4x100 54.00 ET:51.00" I believe) for a set of steel wheels (with tyres, if possible) for my Golf........
Jul 11, 2014 20:45:45 GMT
would the tyres give the right roling radius ? if not flog 'em on and release some fundage
Jul 11, 2014 21:11:27 GMT
Jul 11, 2014 22:00:28 GMT
£25 each ? even £50/set is better than what you have for having to store summat you can't use amd good rubber always sells on here
Jul 11, 2014 22:03:33 GMT
The Hyundai wheels are the rims only. No tyres. Still worth £25 each? Thanks for your help, guz
Jul 12, 2014 20:08:11 GMT
Jul 13, 2014 13:52:49 GMT
Cheers, Woodster. On a side note, does anyone know the size of spark plug socket needed on the 1300 engine? Thanks I've just ordered my parts for servicing. £27! (ECP's don't have a rocker cover gasket, but I'll find one cheap enough) I don't know how to replace my dizzy cap and arm, though (Let's hope I've bought the right one! Just picked the orange one, the same colour as mine....) It has a metal "cage" over it. Does it just unclip? What's it for? Thanks
Paul
Jul 14, 2014 14:47:01 GMT
Metal cage?
Do you have a pic?
Jul 14, 2014 17:04:13 GMT
A pic? Just for you, buddy Hope you like my lovely white "circle" around the "cage"
jonxs
Jul 14, 2014 18:07:31 GMT
Yes that looks to me like it just unclips from the housing Sent from my RM-821_eu_euro1_514 using Tapatalk
Jul 14, 2014 20:25:35 GMT
Thanks, Jon. What the hell is it for? I think it's got an earthing strip on it.......I've seen pictures of other 1.3 engines with it missing, though.
jonxs
Jul 14, 2014 21:28:46 GMT
I have no true idea, but i believe it's what holds on the 'cap' rather than screws. The ones that don't have it fitted must be a different dizzy housing. Don't hold me to that as I've not ever worked on one of these engines. Its just through experience of working on other cars. I will hold my hands up if I'm wrong :S
Jul 15, 2014 15:05:22 GMT
Ah, cheers for that, Jon. It makes sense, now. After looking at all of the dizzy caps listed on ECP's, I can see that none of them have screw holes on them.
Had a small set back today. Went into my local Wilco, to see if they had the metal/foil pipe that runs from the exhaust manifold to the air box. They told me that it would be a main dealer only part. Any ideas as to where I could find one? (As I doubt even my local VW dealer would even stock them anymore.....) There's a picture of the piping on the previous page. Cheers
EDIT: I've also got a rocker cover gasket. It there a set way it goes on? (As I know there's little cut outs on the top of the engine) Will my Haynes manual tell me how to put it on correctly? (Very sorry for the stupid questions.....)
adam73bgt
Jul 15, 2014 16:40:36 GMT
Just go to a scrapyard and get one Mate of mine has a Mk2f Polo with the same pipe, only cost a couple quid at a scrapyard if that
Jul 15, 2014 17:14:46 GMT
Thanks for the reply, guys. Off to the scrappy, I go! Oh, and I got a bit carried away, this afternoon (As the weather was pretty good) At least the car will look nice when it fails the MOT (LOL)
Jul 16, 2014 18:43:07 GMT
Well, I had a very busy afternoon with the car (Nice to have some time off work to be fair - Thanks to "Mr. Phoenix" for the assistance ) The engine bay has turned from this: To this (Painted the top of my rad and heat shield with stove paint - much tidier) Now sporting the satin black badge in the grille, as well................... And now the interior's now got a bit more "bling" in it: Jobs also finished today are; New rocker cover gasket, wipers, oil change (and flush - the oil was like tar) Bit worried the whole of the engine is caked in oil, though And also we managed to remove one spark plug. I'll be buying a 21mm plug socket for my longer bar, so we can complete the other three. Had fun with the plugs, as well. Didn't realise that you need to remove the little metal end cap on the plugs so they fit into the HT leads. That took a few minutes for the penny to drop..... Managed to get the cam belt cover off, and the belt was a "Motaquip" item. So, it must have had it changed sometime in it's life, as it's an after market part. God knows when, though! I'm going to wrap the breather pipe in aluminium tape (any suggestions?), as I think it's save-able (I've trimmed off all of the damaged parts, and it only has one small hole in it) Something like this: www.screwfix.com/p/no-nonsense-aluminium-foil-tape-48mm-x-50m/35529#Or this?: www.wilcodirect.co.uk/product/general-maintenance/Elephant-duct-Tape-Silver-45MSo next on the list is to sort the little bits of bodywork, and finish the service/cleaning the engine bay out. I've also got new front indicators and side repeaters (As the NS one's hanging half-way down the wing!) Then it's MOT time! Many, many thanks for all the help
jonxs
Jul 16, 2014 21:09:11 GMT
Id say do it. Otherwise gaffa tapes also great for that (used it on my old Volvo for a similar application) Looking good with the bit of detailing you've done. Best of luck for the m.o.t mate ??
Jul 16, 2014 21:21:12 GMT
Thanks, Jon. I'm buying some ally tape tomorrow (Just bought some mats and a parcel shelf strap, as well! I can't stop!)
Oh, and why the sad smiley and the question marks? You know I love ya! (In a purely car-based way, of course......)
