I'm changing the engine and gearbox in my Marina based Marlin kit car for Spridget 1275 items.
The original (modified) Marina prop shaft had a sliding joint but the Spridget gearbox takes a sliding UJ instead.
There is no floor in the vehicle so easy to see rear of gearbox and diff flange.
The engine and box haven't yet been installed.
Plan is to try (looks possible) to use the standard Spridget prop shaft - I'm changing the diff flange for a Marina item - UJ's are the same on both vehicles so easy job.
With prop slid into the gearbox and bolted to the diff I can then determine the engine and gearbox mounts.
Problem however is I have no idea what allowance I should make for the position of the sliding section of the prop into the gearbox. If too small then axle movement might push it into the gearbox until jammed solid and cause damage / handling problems. On the other hand if too large a gap there could be a chance it can pop out !
So question is what sort of position should the sliding aspect of the prop shaft be in the gearbox - I'm thinking / guessing, say, 3/4 in ?
Thanks.
Paul H
Thanks.
Paul H
