This silver C-reg RX7 has been in storage for several years. It is a restoration project, but a relatively simple one and not beyond the amateur DIY enthusiast.
It has only 83k on it. The engine runs, although not on the old fuel. It is not smoky on startup or during running - it appears to a be a good little unit. It is the non-turbo model.
The electrics almost all work. The digital console clock works, as does the pop-up headlights, the electric rear hatch switch, the front and rear wipers, and the rest - with the exception on the electric windows, which are stuck.
The sunroof mechanism works perfectly. The sunroof is detachable, and amazingly the slip-in cover bag for storing the sunroof panel is in perfect condition and included. Also in the boot area the original luggage straps are there and in excellent condition. There is even a working, excellent retracting RX7-monikered load cover.
The interior is red cloth and is stunningly good. There is no wear to be found on any part of any seat, and the carpet is in good order and just needs a light clean. All the handles and red plastics are good and uncracked - although the central arm-rest is loose. Steering wheel and gearknob are in fantastic order. Roof lining is not dirtied and still retains a deep red luster.
The wheels are all in great condition, tyres all holding air but best renewed. There are 6 matching wheels in total.
Body-wise, the passenger side is fairly good with just a couple of areas needing addressed. The drivers side rear arch and one end of the sill need welding, and the bottom of the wing, but overall a very solid car with three sill corners all strong and the doors, roof and front/rear ends appearing rather solid.
There is virtually no history with the car, it is a blank sheet. It really does deserve to be rescued and revived and all you need to part with to do so is £1000.
Located Dungannon, N. Ireland. Call 07749520510.
