1987 Renault 5 TL Deleted
@Deleted
Mar 16, 2015 16:21:21 GMT
Tried these old things on again since it's lower than it was when I last had them on. (14x9 ET23) Not sure why they're pink but they are. They would actually fit if I could add a bit of negative camber but I'm 99% sure you can't on a 5¿
Last Edit: Mar 25, 2015 11:05:04 GMT by Deleted
Adey
Club RR Member Number: 171
1987 Renault 5 TL Adey
@adey1984
Club Retro Rides Member 171
Mar 17, 2015 11:25:22 GMT
you can add camber, its not easy and involves heat as far as i know.
@Deleted
Mar 18, 2015 15:01:41 GMT
Rears fit but have a lot of rub.. scratching my head a bit for a solution. Narrower tired would be the obvious choice but 3 of the tires are good cond and one is brand new so
Mar 18, 2015 15:05:32 GMT
I think you should fit the ATSs but in red instead of black inner colour
'80 Datsun Sunny B310(totalled)
'82 Toyota Starlet DX 4door(sold)
'82 Toyota Starlet DX 2Door(sold)
'00 Mazda Miata NB(traded for
'95 BMW E36 318is(traded for
'97 Mazda Miata NA(sold)
'83 Honda Accord(now at Honda Heaven)
'91 Honda Accord(current ride)
@Deleted
Mar 18, 2015 15:21:36 GMT
Think I've got one side done alright. I'll try the same on the other side and then give it a proper drive to try it right
@Deleted
Mar 18, 2015 17:40:07 GMT
got it spot on, no rubbing at all
sridgett
the only way is Dagenham
Mar 18, 2015 17:45:42 GMT
Beautiful!!! I live the 5! And that's one of the best I've seen!
Mk3 capri, escort xr3i, mk2 fiesta,mk5 escort rs2000
@Deleted
Mar 18, 2015 18:21:32 GMT
Well after today's result now the wheels are sorted (minus paint on the single one that doesn't match), time to move on to the next stuff - like that god awful arch gap at the front. It's especially annoying since the car is lowered the same height all round, but there's a huge arch gap at the front and wheels tucked nicely into the arches at the back. Lowering the front will throw off the neutral rake I've wanted for so long, so I think some slightly higher profile (60 or 65) will hide it. The lazy choice, but probably the best choice in this instance. I had/have the rack off too, hits a dizzying 188mph 88mph Beautiful!!! I live the 5! And that's one of the best I've seen! Thanks bud! I'm strangely attached to them now, might have another one coming soon.
sridgett
Mar 18, 2015 18:33:30 GMT
I can't blame you mate! I live in France so I see a ton of em
Last Edit: Mar 18, 2015 18:34:24 GMT by sridgett
Mar 19, 2015 21:00:34 GMT
Any updates on the Escort?
@Deleted
Mar 19, 2015 22:01:26 GMT
Any updates on the Escort? None yet, it's got no battery and I haven't really got enough quid for a new one + the other bits it needs to carry on with it currently. There's a few bits on the 5 that need doing, and since I drive that every day and the Escort never I've gotta prioritise it
@Deleted
Realised I forgot to add pics with the ats' Pre wheels.. Test #1: Releasing the jack released me into the problem - arch rub. It did manage to move though, but was pretty bad. (Yes I was curse-worded off at the tire fitters for putting the wheel weights on the outside..) Anyway, the car decided to fix it's own problem. I pulled that off (as it's already clear, that plastic arch is barely holding together) Success! It moved and has a lot of clearance The plastic on the other side never cracked, so I did it with a grinder because it's fast easy etc Some people suggested doing the centers red, but they look much better black imo. (this is the spare orange one I bought on it's own) Then I painted that to match the rest. Happy with how it came out, going to give them all a good polish soon and see how shiny I can get them to be. Rack again (sorry I like it despite how industrial it looks)
Last Edit: Mar 25, 2015 11:05:52 GMT by Deleted
@Deleted
Mar 21, 2015 19:37:19 GMT
Love it on the classics, But realy realy prefer it without the rack on. Looks soooo clean and subtle.
@Deleted
Mar 21, 2015 19:55:21 GMT
Love it on the classics, But realy realy prefer it without the rack on. Looks soooo clean and subtle. Thanks! I definitely agree so I tend to take it off from time to time. Sunroof opens when its off too which is nice.
@Deleted
Mar 25, 2015 11:04:36 GMT
Pas has kicked itself back into life, still a bit temperamental though. Exhaust scrapes and rattles all the time so I tucked it up closer to the underside and found the culprit broken exhaust hangers that caused the rattle. Started tidying the engine bay up a bit, the huge ugly airbox is gone now and much better. Think I'm happy with the height it's at too. Before: After: Picture and lightings not identical but you get the idea. Going to make a start on polishing the wheels today too
Mar 25, 2015 11:50:45 GMT
looking good .. i'm still not sold on the roof rack but it's your car your way ..
wondered if you were going to paint the sills black below the side mouldings on the above pic to make it all two toney?
steptoeshaw
Yorkshire and The Humber
4 Rover SD1 V8's and an MG Midget. The rest of my cars aren't retro yet
Mar 25, 2015 20:23:05 GMT
Looks brilliant. Alot more red in colour than mine, has it had a re-spray? Mines more orangey red than red.
@Deleted
Mar 25, 2015 21:40:05 GMT
Looks brilliant. Alot more red in colour than mine, has it had a re-spray? Mines more orangey red than red. Thanks! It's definitely been resprayed at some point yeah, to what extent I'm not sure. It came with a tonne of receipts but none for a full respray - just little bits. You can see it on the doors, whoever did it painted straight over the locks. The boot struts also have overspray on them, as does a little part of the ns headlight visible when the bonnet is opened. That being said, I'm fairly certain what has been done was done to match the factory colour since I tracked down photos of it from the owner who had it before the guy I bought it from who had bits redone. Comparing those to ones I have now, it looks the same - and I think they do go a little orangey in the sunlight.
Adey
@adey1984
Mar 30, 2015 20:11:29 GMT
not sure if its in here, what size are the wheels and offset? they sit really nice
