Feb 12, 2015 20:49:17 GMT
Hello all.. picked up a cylinder head I took in for skimming.. so the story diesal freelander headgasket blown.stripped the head to it in to my local resurfacing place...said they would have to machine the valve seats and valves as well as the head...ok left it with them 3 days later they rung said it's ready to pick up... now started to reassemble and noticed all the ports.water jacket.valve orifice.were full of swarf..now I paid £120 for said service ..is this common practice for machine shops to leave bits in there.. or is it just lazyness..?? Anyone else expirenced this ??
Last Edit: Feb 12, 2015 20:50:42 GMT by 86corolla
Feb 12, 2015 20:53:53 GMT
Fairly common (poor) practice I'm afraid. £120 doesn't sound too bad tho.
James
Feb 12, 2015 20:59:12 GMT
Ok no probs wasn't sure whether to complain or not lol
Feb 12, 2015 21:00:41 GMT
Make sure you get it all out, I think the argument is if they clean it and miss some then its going to be their fault when it all goes wrong later, better for them if you clean it. It would have been nice of them to point it out though.
taurus
Feb 12, 2015 21:07:31 GMT
The guy I use presents them back spotless - but he's the one chap all the good local workshops use so I guess he's a cut above the rest.
Feb 12, 2015 21:10:08 GMT
Make sure you get it all out, I think the argument is if they clean it and miss some then its going to be their fault when it all goes wrong later, better for them if you clean it. It would have been nice of them to point it out though. iv given the head several good blast with a blow gun.seems to of shifted it all had a good look in each hole with a good torch
Feb 12, 2015 21:19:02 GMT
Thats poor practise if they cannot spend 30 seconds blasting it with compressed air . Fairly standard to do after machining anything , it suggests a lack of care to me .
Feb 12, 2015 21:59:26 GMT
Thats poor practise if they cannot spend 30 seconds blasting it with compressed air . Fairly standard to do after machining anything , it suggests a lack of care to me . worth kicking up a fuss
Feb 13, 2015 16:41:10 GMT
That's a bit toss to be fair, the bloke I use gives me stuff back clinically clean and is cheap as well, not really worth kicking up a fuss over, if they send a head back like that obviously they think it's acceptable so won't really see your point of view
Just don't use them again,
Last Edit: Feb 13, 2015 16:42:36 GMT by fordperv
slater
Club RR Member Number: 78
cylinder head skimming slater
@slater
Club Retro Rides Member 78
Feb 13, 2015 17:24:21 GMT
curse word off you lot. You pay for machining you get machining. If you have half an idea about engines its going to be cleaned before you assemble it not when it comes off the machine.
110% not normal practice to clean peoples heads for free. If they ask for it however..
Feb 13, 2015 17:29:38 GMT
So not even 30 seconds with a airline is too much to expect ? I obviously have no idea then .
Feb 13, 2015 18:02:58 GMT
Hi, I agree with slater, I wouldn't expect it to be cleaned only the excess wipe off the surface at most. I would clean it up before building it up even if they had cleaned it. Better to do it twice than not at all.
Colin
Club RR Member Number: 160
cylinder head skimming Rich
@foxmcintyre
Club Retro Rides Member 160
Feb 13, 2015 19:39:54 GMT
Cylinder heads comes back from my machine shop spotless and reassembled. At similar cost to the OP. So yea. I think it's just a case of who you use, innit.
Feb 13, 2015 19:59:52 GMT
curse word off you lot. You pay for machining you get machining. If you have half an idea about engines its going to be cleaned before you assemble it not when it comes off the machine. 110% not normal practice to clean peoples heads for free. If they ask for it however.. yea but the point is you shouldn't have to pay extra for them to blow an airline through it...thats like being at home dropping a glass on the floor and leaving it for someone else to clean...
Feb 13, 2015 20:39:28 GMT
Its a matter of cleanliness as well . I don't machine things and then give them to people covered in oil or swarf becuase they will get filthy and possibly cut themselves .
Fungus
Feb 13, 2015 21:21:09 GMT
I wouldn't expect it for the £40 I pay to get heads skimmed, but for three times that amount you would assume they'd clean it.
Feb 13, 2015 21:33:29 GMT
I wouldn't expect it for the £40 I pay to get heads skimmed, but for three times that amount you would assume they'd clean it. It wasn't just a skim though was it, think op said new valves and recut or new seats as well?
Fungus
Feb 13, 2015 21:35:57 GMT
My mistake. I still feel that it should have been cleaned, but as had been said, it all depends on who did it I guess
Feb 13, 2015 21:50:14 GMT
My mistake. I still feel that it should have been cleaned, but as had been said, it all depends on who did it I guess Had the head skimmed..oil residue over head surface...had the valve seats machined and the valves machined..paid £120 in total...Most of the water ways were full of large chunks of swarf.lots of tiny shavings elsewhere on the head...
cylinder head skimming stealthstylz
@stealthstylz
Club Retro Rides Member 174
Its just down to who you use. Some clean, some don't, doesn't matter what the price level is. As long as the work is good it doesn't really bother me either way.
