Hi all
I need help
i have a corsa b shape combo van and decided to convert from wet pas to eps as i had another car just sitting there with all the bits on it.
the idea behind this is to free some space up to run a belt driven air compressor in the engine bay.
my problem is after removing the eps from the donor car and wiring it up to my combo van it does nothing,
the ecu doesn't even click.
i basicly wired it to the clocks and added a 50a live and good earth as i believe the clocks out put the necessary speed and rpm signals
does any one know anything about the eps system and if it works with the diesel rpm signal source
any help will be massively appreciated.
kind regards
edubcee
I need help
kind regards
edubcee
