Feb 24, 2015 20:43:11 GMT
I have an aftermarket Garage Vary GRP bumper for my MX5 the only problem is the bottom is a bit roached, so i would like to cut the bottom off a spare standard PU bumper and Gv lip and mate the 2..
So can anyone give me some advice on how to do this and what to use?
Cheers
Steve
Ginetta G15 BMW K1100 conversion Sold Mk1 Mx5 on ITB'S Sold TVR Chimaera 400 supercharged MR2 Red Roadster 2ZZ Bee*R 324 Skyline 95 Cherokee Jeep
Feb 24, 2015 23:37:22 GMT
Use panel bond or similer. same stuff as factory's use these days
Feb 25, 2015 15:59:40 GMT
tiger seal should do it
Feb 25, 2015 17:40:05 GMT
I would use polyurethane or windscreen bond as it's also known, look up Rejel on Google and I am sure that they will have a kit suitable for your requirements, I have been a windscreen fitter for over 20 years and have used bond to repair furniture, for coving, trims/mouldings, panels, windscreens and tons of other stuff, then correct primers for your needs is what you will need rusty
MK2 Cortina Estate
Feb 25, 2015 19:32:12 GMT
Tiger-seal is good stuff. "Other grab adhesive products are available" : Sikaflex, Serious Stuff. You can get them in places like B&Q and Screwfix. There are so many other sealant products in those places too, but if you make sure the packaging describes it as a heavy-duty exterior grab adhesive, you'll not go far wrong.
Feb 26, 2015 11:20:20 GMT
As darrylwebb said sikaflex is good stuff but will cost more than they Dinatroll bond sold by Rejel, what ever you use it has to be made for the job required and if they parts to be stuck are not prepared correctly and primer not used you could end up wasting your time and money prep and primer and you will have no problem rusty
MK2 Cortina Estate
heathrobinson
Broken everything
Club RR Member Number: 111
Fixing GRP to PUheathrobinson
@heathrobinson
Club Retro Rides Member 111
Feb 26, 2015 16:16:10 GMT
I use tigerseal for almost everything - it's a PU adhesive for bonding in windscreens etc, sticks like sh1t to a furry blanket, and my first choice for everything from bonding double glazing into my mate's truck, to repairing my boots.
Thanks for all the replies i now have an idea of what to buy.
So by prep i guess you mean making a decent key by using something like 70 grit ?
As i am joing two very thin panels what do i use to bridge the gap between the 2 ?
Feb 27, 2015 20:27:37 GMT
sikaflex is good stuff but will cost more Agreed on that. I used to swear by it. Now I swear at the price of it.
