hi all. I'm spending the weekend sticking a 2lt pinto n 5 speed in the neverending m1 escort project.
I know its meant to be the easiest conversion in the world but I'm having a problem with the box. I have the correct lowering blocks for the gearbox but unfortunately I don't have the right crossmember. the original x flow crossmembers have got lost somewhere along the lines and the one I have I belive to be a Cortina one as its "arrow" shaped rather than straight across.
basically I want to know if anyone has any advice on where the box should go height wise. I'm making a custom crossmember using the middle of the crossmember I have and some heavy gauge steel. I don't want to have the box too high or too low and cause issues with the prop. also it pivots the the engine so it gets closer to the underside of the bonnet if its too low at the back
I made up a crossmember yesterday and it all looked ok but when I looked at the car from the side the mount seemed to hang below the chassis rails by about 1.5 to 2 inch so I'm thinking its gonna hit every speed bump n lump in the road.
I'm probably over thinking it but its doing my head in. ford forums tell ya to pop to the breakers for a sierra crossmember but I haven't seen a sierra in a scrappy for years!
