Jun 12, 2016 10:01:38 GMT
Wow, amazing thread. I've just read a load of it in one go. What happened to the big old Bluebird? I saw the photos of it painted and being towed away - did you do anything with the interior? Fantastic skills - thanks for sharing! I repaired the vaneer rubbed it all down and re varnished it painted the roof and wired it also got it re upholstered it looks ok inside I do the interiors but they don't really float my boat so always try and get out of totally finishing them
Caravans are cool
squonk
Jun 12, 2016 11:09:44 GMT
There was also the even smaller Sprite 400. Didn't the 400 get renamed to Cadet? Or was it smaller than 10'? The 400 was no longer in the range when I worked with them. Maybe, A quick Google suggest there were two Cadets, a Cadet 10 and a Cadet 12. Perhaps the 400 became the Cadet 10? I'd never heard of a Cadet 12 - wasn't the Alpine 12' too? Seems strange to have two 12' models in the range back in those days.
Jun 22, 2016 17:43:37 GMT
the sprite is apparently a 1966 sprite 400 , also been gardening for a friend and found a 14ft paladin from the 50s , knocked on the door but no answer
Only discovered this thread now and read through all 12 pages. Amazing new world! And your skills! Kindly keep posting!
1986 Mercedes 200 (W124) (Standard and daily) 1976 Peugeot 404 1800 Stickshift (Standard - awaiting complete resto, engine done) 1984 Ford Cortina (P100) LDV - Cab and chassis restored, interior and glass not fitted, brand new 3 liter engine (last 110kw Sierra XR6 engine fitted and married to 5 speed Toyota Gearbox), load body needed.
Duplicated
Last Edit: Jul 25, 2016 8:59:00 GMT by dubbelduwwel: Duplicated
Jul 26, 2016 17:23:10 GMT
I'll have some more weird and wonderfull stuff to post shortly Cheers for looking Gary
Caravans are cool
dikkehemaworst
Club RR Member Number: 16
Caravanning dikkehemaworst
@dikkehemaworst
Club Retro Rides Member 16
Jul 27, 2016 11:08:48 GMT
That a whole New world opening up for me and what a beauties out there. And wat a craftmanship. Thread is bookmarked And hope to reader some more. Thanks
fpk
Jul 27, 2016 18:46:10 GMT
I never thought I would say cool caravan. But I have 👍 Great work fella.
Jul 30, 2016 17:33:42 GMT
Most of the stuff I've being up to lately has been fairly mundane not worth showing This is the begining of the winter crop of restorations there are about 4 of these due in It's a Viking Fibreline 1969 it came a couple weeks back for the chassis checking brakes ect and a skylight making and fitting This is the skylight I made for it
Caravans are cool
Jul 30, 2016 17:52:13 GMT
The a frame was very rotten indeed each side had a 6" lump missing out the top of the rail with a bit of 2" by 2" box welded in to the rust all a bit ropey The customer wanted an alko hitch putting on fare his summer holiday in it so we brought that forward Unfortunately it's not so simple to just bolt on a new hitch to a 45 year old peak chassis here's some issues The tube is too wide The hitch will foul the handbrake and jockey wheel and a frame cover So we decided to change the whole hitch incuding the bit that bolts to the a frame jockey wheel handbrake and all But the old hitch and a frame was 75 mm narrower than the new and it had a reverse lever the new depends on auto reverse back plates to work
Caravans are cool
Jul 30, 2016 18:05:15 GMT
I put a new wider a frame on it to suit the new hitch I made the old and new metric and imperial brake rods talk to each other by clever use of the old adjuster
Caravans are cool
Jul 30, 2016 18:11:54 GMT
I put the 2 straps on to carry the gas box and bottles the old a frame was rotted by the screws for this leaking in to the chassis rails for years so worst thing my straps will rot and not the a frame itself
Caravans are cool
Jul 30, 2016 18:18:25 GMT
As I said the old hitch had a reverse lever wich allows the brakes to be held off while reversing the caravan most caravans built before 1972 had this lever after that the auto reverse function was built in to the back plate of the brake drum and so alko ones are today I had to find auto reverse back plates bearings and hubs to fit the existing swinging arms kingpins and brake rod mechanisms What a curse word job lol
Caravans are cool
Jul 30, 2016 18:26:46 GMT
All was working as it should so I had to make it look fairly original The a frame cover was now too narrow too high and the holes were at the oposite sides to what they should be I cut the a frame cover in half made a jig to hold it all in the right place blanked the old holes the fireglassed it all up cut the jig away smoothed the old holes out with gob Then used the donor 2015 Stirling Eccles a frame cover to mark the holes in the right place on the 1969 a frame cover This is the result
Caravans are cool
Jul 30, 2016 18:36:12 GMT
I have a sprite Muscateer to play with next week lots to do with this should be fun
Caravans are cool
Jul 31, 2016 16:53:46 GMT
not the biggest caravan fan more so the more modern stuff but I love reading the updates on this thread,
your work and talent are awesome sir
I found this lurking in the weeds It is or at least was a 1930's dove dale 15' touring caravan I have the old windows some panels and the badge and a photo of it from about 20 years back when it was still standing
Caravans are cool
I'm not doing a restoration on this it's going to be a freestyle type thing in the shape of a 30's caravan with some modern stuff it's going to have a solid fuel stove a fixed bed a toilet small seating area and some kind of very basic kitchen The chassis is mint it was built to last there is no rot at all the legs wind up and down the hitch works it was towed to my workshop Blasted
Caravans are cool
What a thread and what craftsmanship!
Looking forward to seeing you restore the Sprite; had many holidays in Sprites and Monzas.
Bookmarked obviously
I envy you mate .Working for a caravan company for a number of years a lot of these old caravans came thrugh our shop, only to be sold to pikes .Nice work and you do on these .So they live on and are not gone for ever .Wish you all the best in your venture..
