I'm late to the party as far as advice goes - sorry this post had passed me by
I saw this in 2006 but first I need to set the scene
Background I'd spent 3 years restoring a Senator 24V that was perfect when I purchased it bar the snapped cam chain only to find the rear end was full of wag and I was gutted so I decided to leave the Vauxhall/Opel world I'd known for decades and defect to the dark side
OK so first as I got it (or rather what prompted me to view it)
Back
Side
Front
Inside (My favorite bit - got a bit of a thing for black leather)
So I bought it for £6000 with 94,797 miles in Nov 2006 - dealership demonstrator for 3 mths then company owned for 5 years then part exchanged for a Merc (spoke to the first owner who wished he'd kept it but the accountant has advised him to change) then 6 months with a new keeper who got himself into a little bother money wise and needed to raise some cash in a hurry so it was a bit of a bargain.
Then on the way home I called into a mates house (he wanted me to buy his V12 E38) and relieved him of some parts
And
Well it stayed std for 15 miles
The tyres were toast so alternative wheels and tyres were needed to keep it legal
I also transfered my Senator plate to the car
Car Park Shots
I love basket weaves but they are such a curse word to keep clean
So I stripped the 18's (for some reason they look really good in the pictures proving that bloody cameras do lie - they were awful condition)
Became
I needed to make sure I didn't lose the bolts
And the centres got blasted and coated
The alloy once the laquer was removed seemed to be black to the core and wouldn't polish so I threw it all in the garage loft and forgot about them..... Till
gewy (Paul Christian) wanted to try one of the rears on the front of his project car so I had to put one together roughly (with four bolts - I hadn't lost them)
Anyway the wheel at 9 1/2 J x 18 was too small for what he needed FFS and as the alloy had gone back to grey I thought I'd better finish them......
7 years later I finally fitted them....
After
Detail
I haz dish
The following points are already taken as a given.....
1) Yes it needs beating with a large and heavy stick
2) Yes it's seen a mouse and is very frightened
Just as a heads up I haven't put a car into a garage for any work other than an MOT test or tyres since the late 80's - I do everything myself (well sometimes with a little help as a group of us pool resources and tools and it works very well)
It was supposed to replace my Senator and Lotus Carlton
It only replaced one of them......
The context of the post below might seem odd but it was written a while back on another forum but it might be useful here
Anyway back to the 740 and back to 2007.......
So when I got the 740 I was happy with the autobox change quality of my 740 when I bought it
Happier still when I drove my mate Wills 540i - it was nasty very jerky and slurred changes
However I gave him a hand to change the gearbox oil and filter and the difference was amazing - chalk and cheese
Bad news was it now had a much better shift than mine in terms of change quality and I could see that my gearbox wasn't functioning as it should
- the tacho was slow to drop when changing into top
- slow speed changes could come in with a bang
- general slurred changes rather than crisp
But what I wasn't happy about £9 per litre plus vat for the oil!!!
The filter and gasket however was less than £28 inc vat from BMW!!!
So we searched and found a cheaper source for the oil
- obviously he wanted to do a couple more changes and I wanted to do at least 2 so we split the cost of it 50/50
Anyway today the 740 had it's first autobox fluid and filter change in nearly 100,000 miles
Over t' pit (As the yorkshire people might say)
Where I'm going to be concentrating on
I reckon my camera lens was a bit grimey!!!! I cleaned it and rest of pics are OK
First and
very important make sure you can undo the filler plug
Don't remove it as you will get very mucky - just crack it
The level in the sump when the engine is not running is way above the level plug!!!
Next drain the oil
Remove sump plug
Drain oil (it comes out real fast)
Then start undoing the sump bolts (leave four in the corners)
Then loosen the two furthest away from the drain plug and undo the two closest to the drain plug completely
This will help to ensure the sump pan has a lot less oil in it when you drop it completely.
When the oil has stopped dripping put the bung back in, undo the last two bolts and drop the pan.
Here's the pan
And the magnets
Next clean the magnets and pan
Time to remove the filter (keep a bucket handy)
And removed
New filter (Part number info) O ring is not supplied with the filter)
And unwrapped
Fit O ring
And replace
Sump bolts all done up
Now we need some oil (£85 for 20 L - ouch but still a nice saving)
Transformer
Pump
Fire in the hole
Slow going but going down
Going down
Going down
Going down
At this point it started dribbling out so
Engine on and AC on full to give a increased idle speed
My mate Will worked it thro the gears to fill the galleries and we kept feeding it the oil
With the engine running finally it started to overflow again
Gearbox temperature at this point was 54 deg just inside limits
Pull the tube out shut of the pump and bang in the filer plug before too much oil is lost
So to give an indication of how much to put back I measured what came out
5L exactly
It took 4.75L at the first fill but I reckoned that was not allowing for filling up the galleries properly so I took it for a drive to propperly fill up all the galleries etc
Now you need to let it cool right down so time to change the plugs :lol: (I'll skip this bit cos it's not relevant)
So plugs changed and trannys cooled (ish - damn these engines hold their heat!!!)
Roll it over the pit
get the pump running back into the container less delay in filling the pan
get my mate Will to fire her up and with the AC on settle on a fast idle
Filler plug out
pipe in and top her up
Took about 750 ml before it started running down the pipe
Filler plug back in and shut it down.
Gearbox temperature by that point was 46 deg.
So whats the difference
Gearbox change quality - sensational
it no longer slowly drops the revs when going into top and whilst you can't feel the gear changes the tacho tells a big story with nice positive drops and none of the slow decay that was there before.
Job done I reckon.
