60six
Sept 3, 2017 10:24:33 GMT
Ever since I bought my 900 turbo, It has leaked a tiny amount of oil. It's done 270k so I just assumed that happens naturally. Thought the flywheel crank oil seal was the main culprit - but during a recent resto after standing 8 years, this got replaced. Then the turbo oil feed return, then various other seals etc - even after jetwashing I could never pinpoint the exact cause. Every previous MOT states minor oil leak. There's a tiny little valve on some vac hose going from the intake to the crank breather. It was around the wrong way. causing pressure in intake to pressurise the engine during turbo use, pushing oil out the existing seals. Turned it around. Fixed. Thought about all the things I have tried and the hours put in to rectify! Such a tiny irrelevant looking component!
Sept 3, 2017 11:01:12 GMT
BMW e30 , whining diff . I did 30k on that , it never got worse . The car was killed by a faulty ABS block which were unobtainium them or £500 +
Sept 3, 2017 12:07:26 GMT
My wife backed into my Mazda about 500 miles after I bought it off the showroom floor. The rip in the cover is still there. It's not winning any beauty pageants.
Ryannn
Sept 3, 2017 13:03:58 GMT
I've driven a mini for 12 years... lol
Last Edit: Sept 3, 2017 13:04:31 GMT by Ryannn
glenanderson
Club RR Member Number: 64
Sept 3, 2017 13:10:54 GMT
Clutch judder on my Land-Rover. Drives me mad. I've made it better, but never cured it completely. I've changed every single component, more than once, over twenty four years, and it's still there.
Sept 3, 2017 13:17:38 GMT
Not a mega issue but it still annoys me, I can't for the life of me get my back box to sit straight, it's slightly wonky and it drives me nuts when I see it. Still, first world problems.
Sept 3, 2017 13:32:01 GMT
I drove my Mini for over 8 years without a screen wash reservoir... Never found one that would fit, and was too lazy to actually find one and fit it... For TÜV I put a random reservoir in the boot, telling the examiner it "just fell off". Always worked.
Sept 3, 2017 15:16:46 GMT
Mondeo radio volume control for some reason works the wrong way round. turn right to turn down, and visa versa. Must have turned the volume the wrong way a thousand times in 3 years, ive got another complete unit, but just never got round to it.
Exhaust also bangs everything i put the car in reverse for some reason.
Sept 3, 2017 15:59:34 GMT
Tracking has needed doing on my Volvo daily for the past year, steering wheel not centered as a result. Planned to get it done when I changed the wheels... have yet to change the wheels.
With the Datsun ... well ... how long you got?
Sept 3, 2017 16:23:13 GMT
RWife's daily is an 2002 Accord SE and the fuel pump Whirr's SO LOUD that sometimes you have to shout over it! Been like it the 3 years and 30k miles we have put on it. It's mounted behind the rear bumper somewhere underneath the passenger side.
Last Edit: Sept 3, 2017 16:23:48 GMT by SmokeEm
Sept 3, 2017 17:38:53 GMT
The CVT on my Panda has been causing trouble for the last 6+ years. The problem - just a little thing called 'creep', where the car will try to drive forward at junctions, and you have to keep your foot on the brake to stop it . Oh and it doesn't go into any other gears when this happens, so no putting it into neutral to stop it. I have accumulated a vast range of CVT bits to help fix the problem, but I never seem to have time to try and fix it.
The Doctor
Club RR Member Number: 48
Sept 3, 2017 18:03:23 GMT
On a car i had a couple of years ago, i postponed the oil change untill i had found and solved the huge oilleak it had. Couldn't find it, even though it was leaking quite a lot. After a year and lots of top ups later i found out it was the oil filter itsself leaking... Changed that and it was solved.... oops
Sept 3, 2017 19:52:57 GMT
Vibration at motorway speeds in the Capri - i sometimes seem to have improved it...other times not. It's just what they do...still annoying tho!
Sept 3, 2017 19:59:42 GMT
Ever since I put the w124 back on the road it's had an annoying rattle from the back end, 4 years, a full suspension rebuild, 2 exhausts, 3 diffs, and countless times poking and prying about underneath it's still there!
ferny
Club RR Member Number: 13
Sept 3, 2017 20:15:40 GMT
Speedo is out by 30% and there's been a vibration which has been present since I got the car 11 years ago which starts at 65mph and is very violent at 70mph. Around 100mph it smooths out somewhat...
The first was caused by fitting a longer diff and the second only revealed its more entertaining facts via an engine change and 100%+ power increase.
adam73bgt
Club RR Member Number: 58
Sept 3, 2017 20:17:57 GMT
For the past year or so, my BMW E34 has had the 55mph 'shimmy' which vibrates the steering wheel in a somewhat annoying fashion. Have changed all the front end suspension and wheels have been balanced but to no avail, currently I'm driving around it, as long as you avoid 50-60mph its usually fine... Also as we head towards winter, I'm sure its ICV issues will start appearing again where it has a very lumpy idle in cold temps and will sometimes cut out.. Still, I should be fixing that with an engine swap when I get round to it
Sept 3, 2017 20:18:07 GMT
So the Carledo makes a funny noise, it's a sort of metallic whirring, from the vicinity of the gearbox, rather as if the propshaft is rubbing on something! BUT, it only happens when accelerating hard out of right hand bends! It's been the same since I built the car in 2010. I've been under it countless times, i've had the gearbox out (for other reasons) there are no visible rub marks anywhere and the prop and it's coupling are so far from anything that they CAN'T be fouling! In 15000 miles the sound has been completely predictable and has got no better (or worse) It takes the dragstrip in it's stride (and no noise cos it's not going right) and has been hammered round many laps of Castle Coombe (with noise on most corners, Coombe being a right handed track)It does everything else right, corners as if on rails, pulls strongly, stops brilliantly, is UTTERLY reliable and surprisingly good on fuel. All except for this blanketty blank NOISE!!!!!
I have learned to ignore it, but it drives me crazy sometimes, new passengers ALWAYS comment and returning ones give the snarky "not fixed that noise yet then?" comment that is guaranteed to make me wish i'd fitted an ejector seat!
Steve
Sept 3, 2017 20:31:03 GMT
I had an Fiesta automatic I was given & the car basically accelerated all by itself for the whole 2 years I owned it. I dread to think how thin the brake pads were as I'd have to be on the brakes all the time.....I imagine that following me was the cause of much cursing!! 😳
Last Edit: Sept 3, 2017 20:32:16 GMT by bungle74
Sept 3, 2017 21:45:32 GMT
Horrendous cam rattle on my Capri because the lobes were worn. Been like it for about a year, ended up changing it at a car show.
2001 vauxhall corsa 1972 VW Beetle 1986 Ford Capri Laser1999 BMW E36 323i Touring 1991 Volvo 940 estate 2002 Mazda 323f 2.0 sport 2016 Mercedes Sprinter 1999 nissan almera 1.4 1995 lexus gs300 1995 lexus ls400 1975 bmw 1602 fiat punto 2003 ford fiesta something else...
rear wash wipe didn't work when I bought my 205GTI.
sold it 7 yrs later, wash wipe still didn't work!!
