pork
only 6k?? pah, just coming on song you can see the torque is only just starting to drop. that really would have been well run in by the time you were half way through mapping the lower rpm sites and ready to take all you could throw at it up top. I wasn’t there whilst he was doing it. Otherwise I’d probably of said to just do it 😂
pork
Feb 19, 2018 15:47:51 GMT
If I’m not using the variable stuff, thought I’d fit some velocity stacks. With the variable stuff, there was a couple of big lips between the 2 stacks, with this it should nice and smooth now.....and it’s shiny 😎 Just waiting on bloke to stick it together
pork
Feb 21, 2018 21:21:37 GMT
Busted out the dremmel to smooth of some of the lips, make it all silky smooth Once the stacks come back il smooth the joins together as well
pork
Feb 26, 2018 12:07:03 GMT
Mot done 👍👍👍😉
pork
Feb 27, 2018 15:36:30 GMT
qwerty
Club RR Member Number: 52
Feb 27, 2018 22:23:43 GMT
Wow! They look ace! Bet they sound great too!
Tom
pork
Yeah man👍👍👍
The car is a bit too loud though 😮 might need to do something to quiet it down, I do have a mid silencer, but the rear box is a cherry bomb type, so I guess il replace that first
Speedle
Feb 28, 2018 16:17:15 GMT
Awesome dude! It's nice to see the Micra modding world is still alive! Always gets me thinking about my k10 miss that little rocket!
pork
Feb 28, 2018 18:53:37 GMT
Awesome dude! It's nice to see the Micra modding world is still alive! Always gets me thinking about my k10 miss that little rocket! I’m partial to a k10 too. Was meant to put this on another k10, but this car sort of ran away with itself. Really want a pao !!!
pork
Purchasers for head build Cg10 head £20 Cr12 solid buckets Got some head polishing tools on order too. Still waiting on any ideas/info for larger valves 👍😎👌
pork
Had a quick go at the Combustion chambers, left the old valves in as i didn’t want to damage the seats, (putting new valves in anyway 👍) Before After........think I can get it more of a mirror finish Gunna be using cr12de valves, they’re the same diameter, but a longer stem, so no need for double shims (if any) and use some lash caps to get the correct clearance for the regrind cams I’ve got 👍👍 Sent from my iPhone using Tapatalk
mk2cossie
Club RR Member Number: 77
Mar 24, 2018 11:51:13 GMT
looking good there I wouldn't worry about a mirror finish in there tho, what you have looks fine, and just chamfer any sharp edges away would be as far as I'd personally go
pork
Mar 24, 2018 12:09:24 GMT
looking good there I wouldn't worry about a mirror finish in there tho, what you have looks fine, and just chamfer any sharp edges away would be as far as I'd personally go Had a go in the inlet/exhaust ports too.....there are some massive steps/edges where the seats have been pressed in, and some horrible casting marks
gn3dr
Mar 25, 2018 20:22:36 GMT
Try get rid of the valve shrouding, the little step around the outside of the valve / valve seat. Nice job on the throttle bodies. I made a few for Micra rally cars in the past and they are awkward because of how close to the port the mounting bolts are.
pork
Try get rid of the valve shrouding, the little step around the outside of the valve / valve seat. Nice job on the throttle bodies. I made a few for Micra rally cars in the past and they are awkward because of how close to the port the mounting bolts are. Will do👍, gunna get a head gasket and bolt it To it and see what metal I can remove
pork
Mar 29, 2018 21:51:03 GMT
pork
Something not right here is it ......🤔😧 Made a homemade leak down tester These are the readings I got on all cylinders Gunna take the head of and see whats going on
pork
Well engines out. Heads off. Pistons out too. Everything looks fine 😧 Ring gap is good. What’s given me this massive blow by???
mk2cossie
Whats the gap like for the other rings of each piston? Cam timing out maybe? Also, any pics of the top of the block without a camera flash And the clylinder head gasket face as well. Although if it were mine, I'd possibly glaze bust those bores
pork
Whats the gap like for the other rings of each piston? Cam timing out maybe? Also, any pics of the top of the block without a camera flash And the clylinder head gasket face as well. Although if it were mine, I'd possibly glaze bust those bores Gap is the same on the others too. The head and block have both been skimmed Cylinder 3/4 look a lot more ‘polished’ compared to 1/2......does this mean anything?
