v8ian
Nov 10, 2017 21:26:46 GMT
Now the cold weather is here, I switched on my electric IR heater, big blue flash as the power went off, its fubared, SO what electric heaters do you gentlemen use in your garages? and how good are they???
Garage HeatersDeleted
@Deleted
Nov 10, 2017 22:36:59 GMT
Infra red for paint curing but a simple thermostatic oil filled radiator for keeping the general chill down / providing background heat - I can use it on it's lowest setting overnight in my 400 sq ft garage and it's 15 + degrees the following morning whilst it's below zero outside - it's quite economical on the electric too - but keeping the draughts out and good insulation helps - I am in my workshop all day so I also invest in decent thermals - the latest lightweight breathable ones are fantastic 'Norde' are the ones that I recommend - you can get them on Amazon fairly cheap
Last Edit: Nov 10, 2017 22:37:25 GMT by Deleted
Nov 10, 2017 22:42:47 GMT
I have a dimplex over door heater, works well,
Blows warm air around well, and not bad to run, not sure on cost to buy as I "borrowed" mine when the firm I worked for went bust.
merryck
Club RR Member Number: 9
Garage Heatersmerryck
@merryck
Club Retro Rides Member 9
Nov 10, 2017 23:14:20 GMT
ALDI have a few different heaters in at the moment, nothing special but cheap and usually their stuff has a 3 year warranty.
Nov 10, 2017 23:21:24 GMT
unless you need it for painting, just get warmer overalls and a hat.
a small fan heater to huddle by to thaw out if necessary.
Nov 11, 2017 10:58:48 GMT
A number of members on another forum I frequent have mentioned diesel fired heaters as being very good at warming a large area quite well.
Nov 11, 2017 20:23:37 GMT
I always use a kerosene fired rocket heater, warms the place up in a shot
sowen
Club RR Member Number: 24
Garage Heaterssowen
@sowen
Club Retro Rides Member 24
Nov 11, 2017 20:35:14 GMT
I've got a pair of these radiators that work really well in my garage keeping it warm (and also for drying paint), but it is fully insulated which helps contain the heat At work there's a few paraffin and propane space heaters that bring the temperature up really quick which is essential with a single skin tin roof!
93fxdl
Enter your message here...
Nov 11, 2017 20:45:40 GMT
There are a couple of warnings for using any fuel burning heaters, be it oil/gas or solid fuel. The first being co2, the second being condensation, every litre of fuel burnt produces about a litre of water. Ttfn Glenn
Nov 11, 2017 23:06:45 GMT
^ Water & condensation I often have a calor gas/propane heater around. They're handy in a room or small workshop but beware the naked flames and the water they create. The heat they give off won't do a lot to heat a big workshop.
@Deleted
The fuel / paraffin / diesel heaters are no good if you are planning on doing painting / spraying has the chance of them contaminating the air / environment around you will greatly increase your chance of suffering with paint silicone contamination
Last Edit: Nov 12, 2017 22:43:47 GMT by Deleted
muffy
I made a waste oil burner and it's brilliant. It's made out of a lpg tank. Being 5 to 6mm thick I still can get areas of it to glow cherry red.
Normally run it about 300 to 400 deg.
The fuel / paraffin / diesel heaters are mo good if you are planning on doing painting / spraying has the chance of them contaminating the air / environment around you will greatly increase your chance of suffering with paint silicone contamination I've used one for years spraying and never had any issues or reactions.
brachunky
Scotland
Club RR Member Number: 72
Garage Heatersbrachunky
@brachunky
Club Retro Rides Member 72
Nov 12, 2017 11:43:55 GMT
I have a dimplex over door heater, works well, Blows warm air around well, and not bad to run, not sure on cost to buy as I "borrowed" mine when the firm I worked for went bust. Interesting you say that as having only a single garage, floor space is at a premium so that over door jobbie may be an idea for me!
Nov 12, 2017 18:43:53 GMT
Nov 12, 2017 19:16:49 GMT
I have a dimplex over door heater, works well, Blows warm air around well, and not bad to run, not sure on cost to buy as I "borrowed" mine when the firm I worked for went bust. Interesting you say that as having only a single garage, floor space is at a premium so that over door jobbie may be an idea for me! Found this one at a fair price, 3kw so should do the job www.toolstation.com/shop/p78313?table=no
Nov 12, 2017 21:58:24 GMT
We bought 10 of the square shaped Stanley workshop heaters they were worse than useless, nowhere near 2000w output when compared to a cheap 2000w one from Argos. Every single one of them melted it's plug and we had 2 melt down, they were all returned.
Nov 13, 2017 11:10:23 GMT
I've been looking at building a waste oil heater too, but all the designs I find online either confuse me, or don't show eough detail on the critical bits.
Either that or maybe I'm just thick!
Anybody found a clear design?
Nov 13, 2017 14:04:59 GMT
Nov 13, 2017 18:29:24 GMT
i got a electric bathroom heater for free and made a frame for it and put it aside where i am working. Don't need to heat the whole garage which takes time with fan heaters. You have direct heat from moment 1 Peter
