foxy99
May 31, 2023 22:13:54 GMT
foxy99
Bump
foxy99
Bump
foxy99
Jul 12, 2023 23:56:17 GMT
Bump
foxy99
Jul 27, 2023 11:14:16 GMT
Bump Still looking as the other one is much worse
Last Edit: Jul 27, 2023 11:17:14 GMT by foxy99
foxy99
Aug 16, 2023 22:30:57 GMT
Bump
foxy99
Sept 4, 2023 22:08:15 GMT
Bump
Sept 5, 2023 10:33:26 GMT
foxy99
Sept 6, 2023 18:06:11 GMT
Thanks for that WL
Seems they are out of stock just now and one bearing is 20mm ID (other is 25mm like I need) so it's a possibility
Sept 7, 2023 13:56:37 GMT
Thanks for that WL Seems they are out of stock just now and one bearing is 20mm ID (other is 25mm like I need) so it's a possibility How about these people autoandtrailer.com/8-4.00x8-assembly-with-integrated-bearing-25mmThe 6204 has the same OD 47mm as the 6005 so you could just change bearings to get the the correct ID both sides
Last Edit: Sept 7, 2023 14:00:25 GMT by dodgerover
foxy99
Sept 7, 2023 17:06:34 GMT
That looks ideal, and you get a free tyre too I just ordered one. £46.68 with P&P etc
Last Edit: Sept 7, 2023 17:10:48 GMT by foxy99
Sept 7, 2023 20:38:09 GMT
That'll be a much safer solution than the existing rims and at least the tyre will be new
foxy99
Sept 15, 2023 21:59:05 GMT
Well I got my new wheel today and am amazed to say it fits very well. The only difference I can see is that there in no provision in the rear of the hub/housing for an oil seal (to protect the bearing). The bearings are RS (rubber-sealed) so perhaps an oil-seal isn't deemed as necessary but I would have preferred it to be the same. I was concerned about the dimensions (length) of the hub actually, before it arrived. Was thinking even if the bearings fit the axle/shaft might not have the right dimensions to get the nut on or would need packers/spacers. However it goes on right to the shoulder that the oil-seal would sit and and plenty room out front for the original nut c/w washer. I've not examined the markings on the tyre yet but it says DOT & high speed trailer so I think it'll be legal/safe replacement wheelseems to fit finesome info on tyreold bearing is similar size to new oneno oil-seal at rear but snug fit on shaft and against shoulder on axleAm thinking I will now repair the corroded original rim, somehow, and mount it as a spare
Last Edit: Sept 15, 2023 22:08:14 GMT by foxy99
