Nov 12, 2006 20:50:12 GMT
My 'Rabid' has got far too much fresh air betwixt wheel and arch. Needs to be less. Not a fan of cut springs, esp with the grief I give cars over crappy tarmac, so want something to go LOW! (the lower the better). Anyone got owt or know where I can get some.
Nov 12, 2006 22:15:17 GMT
www.jhmbuttco.co.uk about £120 for a set of -35/40mm springs. theres another place i cant mind where you can get them cheaper, it might just be demontweeks...
Nov 12, 2006 22:42:06 GMT
-35/40 ain't low! SM project bottle rocket had a set of AVO shocks and springs - for a 5/4 (that's inches!) drop. According to the SM article (suspension instalment July '95 issue) they were supplied by Motech - the number given is 01604 30918...I'm not sure if this is the same company, but it seems likely: www.motechdirect.co.uk
Nov 12, 2006 22:45:44 GMT
More searching has revealed that www.avouk.com list the Skoda in their catalogue...not quite the SM drop though!
Mike D
Club RR Member Number: 57
have you got anywhere near you that makes springs? theres a few round here..... can specify your own drop / spring rates then. I don't think they're that much more expensive than off the shelf springs either
There's Scanda Springs across in Buntingford if you want to get some custom coils made Pog. Very helpful people.
Cool. I'll pay them a visit - that's a nice drive out there:)
Nov 13, 2006 13:22:41 GMT
on my tango estelle with 13'' alloys with 185/60 rubber theres about 1cm clearance between the front arch and the tread... thats plenty low enough for anyone
Nov 13, 2006 16:09:00 GMT
40mm is only just over 1.5"! It took a lot more than 35mm to get down here, in fact I'd guess it was closer to (in mm just for you youngsters) about 70mm: There's alway hydraulics of course!:
Last Edit: Nov 13, 2006 16:09:52 GMT by rmad
