Ben
Dec 28, 2007 14:28:57 GMT
Right due do a stupid warranty my forks are not going to be replaced under it. Gay?!? Anyone know where I can get 100-120mm jump forks and front and rear hydraulic disk brake sets for cheap?? Even if they're second hand of someone of here. Its urgent any help appreciated. oh and I've tried chain reaction cycles but got confused with the site Ben
Ben
Dec 28, 2007 14:32:00 GMT
Ive found this, Does it come with disc included? I'm really confused Click
Ben
Dec 28, 2007 14:34:08 GMT
Also Juicy 5sbut again, do they come with hoses, fluid and disks?
Dec 28, 2007 14:42:47 GMT
the disc setup will be complete. they're a closed system so they'll have a certain length hose and be fully bled ready to be fitted. and yes with a disc. I'd get the juicy 5s, codes are heavy and not alot better. although the link to the 5s youve posted are fronts only. you could look at 7s too
as for forks you wont get much for brand new, try ebay, Fox Vanilla 125R go for about £130 depending how much scene tax there is. other than that look at marzocchi Dirt Jumper Series or MX series
perry
Dec 28, 2007 14:44:20 GMT
" includes 6 bolt rotor " arnt hopes in vogue at the moment
Dec 28, 2007 14:44:33 GMT
by the way DO NOT buy hayes brakes they're terrible and a pain to work on
Ben
Dec 28, 2007 14:58:56 GMT
cheers for your help, I'm hoping this link will work, www.chainreactioncycles.com/WishList.aspxthere should be 3 items in there, ive been told not to go bigger then 100mm jump forks so I'm not. Whats opinions? all i need now is £60.
Ben
Dec 28, 2007 16:06:16 GMT
Well i just bough Juicy 5 185mm front 160mm rear, with the help of gofasterpinch on msn.
Anyone got any recommendation of forks, 100mm tops, IS mount for discs. fair price. say no more then £150.
Dec 28, 2007 16:49:44 GMT
by the way DO NOT buy hayes brakes they're terrible and a pain to work on really? I have hayes hfx-9 HDs, 8" rotor and bargain priced at £60 a set. works sh1t hot and I've not had to adjust the front since installing it. nothing but praise from me. ridden daily for about 2 1/2 months now.
Dec 28, 2007 16:52:24 GMT
well ive had HFX-9s before and i hated them, wooden feeling and if you need to bleed one its a right old chore! i think if they work leave them to it, they're not maintenance friendly IMO!
iv got a set of downhill nines and they are immense and you can get a brand new set for £100 now!!
As for forks I used to run dj2's but now run '07 dj3's which are heavy but very good on ym jump bike
JDM Motorsport
For all your classic needs contact me by pm or email hayley@milli.orangehome.co.uk
thanks
Tim
Deore brakes are very good - shimano are reliable, avid are good but build quality in some areas is not as good as shimano
hopes are ace when they are a good set, a nightmare when they are a bad set - i've had both from new, one was best brake i've had, other was terrible - sticking piston issues, possibly poor machining.
I've got a set of fox floats 100 going spare I keep forgetting to ebay, but they are xc forks so probably not what you are after
Jan 12, 2008 22:23:56 GMT
let me know how the juicy's go for you
Jan 12, 2008 22:36:06 GMT
cant beat juicys imo! i loved my fives.
Jan 13, 2008 14:11:00 GMT
how easy are they to set up/bleed? at the money they better look pretty too
Jan 13, 2008 17:07:00 GMT
easy to setup, no idea bout bleeding ive never done any yet, although i know you need a specific bleeding kit to do it
