all right - big box of parts arived today, so I will be getting it back together, flushed and filled up, hopefully tonight but maybe spilling into tomorrow.
Also getting nightmares about the head gasket being knackered, so I might get one anyway and do it at the weekend.
Anyone local got a compression tester I can borrow?
Last Edit: Apr 7, 2010 12:46:16 GMT by Gas Works
wanted, 25th hour. Required daily, cash waiting
alright! Jobs done last night in the rain-
Replaced the horrible ripspeed gear knob that didnt even screw on! New boot lock so it actually locks Locking nuts on the alloys heater tap on water pump and bypass hose on thermostat in
had to stop there as I had the wrong fanbelt, change that on the way home tonight
tonights jobs - replace leeky door seal fan belt and fit fan fit cowling and radiator check all the hose clips again fill, flush and fill again test drive!
ordered the HG just incase, and a new top hose as mine looks manky. woot
all right - terry lives - its all back together and running like a sewing machine, went for a drive and all was fine temp sits just above the middle mark, but the heater is still a bit cold so think the matrix needs a good flush.
but....can't drive him to work tomorrow, was getting a little squeeky on the test drive. it appears one of the gaitors has lost its zip tie and some grease, so need to pack it out and zip it up tomorrow evening! fun fun fun!
Apr 11, 2010 18:55:12 GMT
alright, so some pics.... New Vs. Old gear knob: Stripped Back together running real good. needs an oil change, that'll be tomorrow. also some of the squeaks are coming from the brakes. Disks are pretty shot so will get them on order. Happy days.
Last Edit: Apr 11, 2010 18:56:19 GMT by Gas Works
Apr 19, 2010 10:19:46 GMT
ok so back on the train to work this week!
Changed disks and pads at the weekend but turns out the caliper was seized on nearside, showed up with the thicker pads in it it was binding.
Tracking down some calipers now and hope to have it back together by friday evening if I can get parts by wednesday.
Also bonded the bracket in the valence on the b and got it bolted up with lots of resin between. mmmm FG sandwhich.
well, testing times with the brakes this week, but they are finally done - along with inner and outer cv on passenger side, bled in the dark, and driven to work this morning. Happy Days.
Next jobs =
Sort knocking exhaust replace suspension cones couple bits of welding stonechip the arches etc waxoil like mad
blend the valence on the GT finnish front valence get sending and filling and sanding and filling
Apr 29, 2010 13:26:04 GMT
well monday night started like this: I then waved goodbye to the nice chap who bought my broken mundane-o then finnished up in the dark: first time ive taken a driveshaft out or changed a caliper. quite pleased with myself. Got some free time this weekend as Mrs GW has gone to see her mum, so lots of garage time for me!
well, I think the MG was feeling a bit neglected after the recent run of work on the mini - so I got on with my sebringness today fg'd it all together and got the roungh profile correct then cave it some filler to smooth it all together finnished flatting back the doors today. will order my filter/reg for the compressor so I can paint them if its warm next weekend happy days
Last Edit: May 1, 2010 17:19:52 GMT by Gas Works
May 11, 2010 17:39:02 GMT
after some help on the main board with rev counter wiring - it worked: so i got some wire, soldered and heat shrink in the joins and got it fitted: nice to get a better idea of what the engine is up to.
Nathan
Club RR Member Number: 1
May 11, 2010 20:08:37 GMT
Good work fella
May 12, 2010 16:35:25 GMT
My B rev counter was dead so did a similar thing to you: Back end is looking nice there I reckon. Be good to see in a colour. You keep tempting me to debumper mine but fortunately lack of skill is keeping me off!
May 12, 2010 20:03:31 GMT
cheers guys.
lack of skill shouldn't put you off monty, i've never done it before, and getting it in colour is going to be another new experience form me. I've got my filter/reg now so once it warms up a bit the spray guns are coming out. Quite excited but a bit aprehensive at the same time.
May 15, 2010 17:31:07 GMT
larger than life update today.... well, i couldn't wait any longer, I had to try some spraying! so I cleard some space and hung my doors up. set up the compressor and gun with my ne filter reg....and don't forget - safety first! got the primer mixed up and after the panel wipe - layed the first coat down. Its a bit patchy as i was playing with the settings and getting used to how it all works. got a better coverage on the bootlid, with a smoother finish too. I was getting too much air through on the doors. while that was drying i had a play with some fibre glass. went back to have a look, but.....had a reaction against the halfords filler primer...on all the panels. I flatted back one of the doors to get rid of these areas, and then used a different rattle can primer over the yellow bits. hopefull this one will work better with the celly. will find out when I do the next coat of primer soon. The repaired door drying: Definately an experience today, its not easy but ive got plenty of paint and a whole car to practice on
May 17, 2010 10:57:24 GMT
I had a reaction with Halfords primer over filler as well when I did the door on the Dolly. Took frigging ages to sand and prep twice in the garage and the end result was a finish worse than the rattle canned on the drive Golf I did previously!
Nathan
May 17, 2010 13:37:45 GMT
I had a reaction with celly on celly so anythings possible LOL
May 17, 2010 20:23:42 GMT
'tis a bit of a pain doing things twice but hey ho, live and learn. hopefully the next layer wont react with the othe primer ive used or ill be doing it 4 times!
been tinkering with terry, this shows the right and wrong shapes for a front tie bar! and this shows the curse word that came out the engine bay! That alarm wasnt wired up to the power, and the 'sound deadening' does a bettor job of either drying up and catching fire or trapping moisture and rotting the bulkhead so thats beeter off in the bin. Evidence of waxoil around the bulkhead too which is encouraging.
Well.....had an issue in the 'torrential rain' on friday. had a small pond in the drivers footwell so I went searching. couldn't take the drain plug out as some clever soul at the factory put them under the sound deadening. Sound deadening came up to reveal a small hole around he drain plug and a poke around showed the door frame, wheel arch , door step and inner sill were letting in water too. wehey. I then did something i've never done before. I took an angle grinder to a taxed, tested, daily driver With two days to get it cut, welded and painted before heading back to work I cracked on. Finding and Cuting the grot: Started templateing and making panels And the bottom of the door post reconstructed as ever, ran out of time, run low on wire and had to get the train to work this week. Woohoo. Going to get some wire and gas. don't like this gasless set up really. Going to order a doorstep and inner sill repair panel to save some time next weekend. Hope the weather will hold so I can get it done! I'm sure plenty of you could have done it in one afternoon, but I'm learning, and I'm sure ill get plenty of practice with this one.
Nov 16, 2010 19:15:47 GMT
not been around these parts much. The above got finished, mini is up for sale and I bought a VW T4 to convert into a camper. Not very retro but will prob juck some pics up if anyone is interested? and the mg has been having little bits of prep here and there so not a total standstill...more to come soon!
Nov 16, 2010 21:28:46 GMT
Looking great, always fancied building a Sebring.. I'd avoid most things from Halfords, especially the paint and primer. Here's a gratuitous pic of my old 'B that I built..
1989 Mini MG 1275 ~ 1987 VW Polo ~ 1989 Citroen 2CV ~ 1998 VW T4 ~ 2006 Volvo XC70
