Jul 29, 2009 19:16:50 GMT
might be wanting a elec fuel pump to run a weber dmtr
ive had a look on ebay and theres not much info
id like ...
super reliable lowest noise engine bay fitment no need for pressure reg not much on ebay seem to suit my needs , i suspect many are for high powered racers ?
anyone got any advise , or where can i read more on whats good/bad , and is the only brand facet ? cant see any others
g40jon
the facet says best mounted near tank...does that mean wont work in the bay or what
cant really find any detailed info on anything...or the facet website
kee
the facet pumps are the best for this application. your best off mounting near the tank but they do work in the bay. also most eleccy fuel pumps will need pressure regulators otherwise you'll flood the carb and engine quickly.
rally design do their own style eleccy pumps and are quite cheap.
the carb has a return pipe , i was hoping if i chose a low presure pump it would be okay ?
i just want simple and cheap really
have you got a link for the rally design stuff...all i saw was facets
PhoenixCapri
West Midlands
Club RR Member Number: 91
Jul 30, 2009 10:18:10 GMT
The Rally design stuff is under the RMD section www.rallydesign.co.uk/product_info.php?products_id=13662&osCsid=ulj8apgub4o3vv1an95rc8ub04 - that one should be enough for around 130-150bhp. Even with a return a hi flow pump (which is what thex are) will flood the carb, and make sure you rubber mount it otherwise it'll annoy the hell out of you! A solid state pump mounted next to the tank with a reply supply, and then a filter/regulator in the bay will work perfect and cost bout 60notes all in. Its the setup I've used for 3 years in the Escort without a hitch
Jul 30, 2009 10:27:03 GMT
how noticable is this clciking ?
The Doctor
Club RR Member Number: 48
Jul 30, 2009 10:53:36 GMT
are bike pumps an option? they stop when they feel pressure, so they only run when needed. they are cheap they work pretty silent
Jul 30, 2009 18:19:20 GMT
yeah id thought about maybe a big bike carb....supply for a big bike must be similar to a 1300 low powered car hey
Jul 30, 2009 23:25:10 GMT
i've got a couple of cars running on electric pumps i don't know the name of. the are have polished, half blue, and have a live, an earth, and a fuel in, and fuel out. work no problem on my 749cc car and my 1.2 and 1.3 cars. SU possibly responsible for one of them?
motorbike pump should pick one up from a breakers for about £20. I had a zx9r carb pump on mine [when I was running the x-flow with a dgv & the bike carbs] which has built in regulator etc & was pretty quiet in all honesty - I had it mounted in the engine bay too. just make sure you get a carb pump & not an injection pump ;D
Last Edit: Jul 31, 2009 8:10:20 GMT by Ratters
