Aug 24, 2009 18:50:37 GMT
went out for a ride tonight , got a few miles in and the front brake started to stick...enough to make mucho smoke from the pads
i pulled up and let it cool off , it free'd off enough so i could limp a few miles home
never had this before...should i expect to fix it by working the piston in n out a few times , or is it deffo rebuild time ?
any ideas where i can get a kit to rebuild if req...its a vw vr6 280mm caliper
Aug 24, 2009 18:54:51 GMT
First consideration - flexi-hoses. They can break up inside and act like a one way valve. Give the throttle and good press and then open the bleed nipple on the caliper. If fluid spurts out and the wheel then turns, you have a likely culprit...
1986 Citroen 2CV Dolly Other things. Check out my Blog for the latest! www.hubnut.org
Aug 24, 2009 18:56:11 GMT
could be a sticky piston, could need bled, could be wrong sized pads/disc, not enough clearance, has it been sitting long? is it OE? when was the last time the pads were changed? etc...
Aug 24, 2009 18:56:15 GMT
Depends whats sticking. Could be a pad sticking in the caliper, a sticky/jammed piston or a twisted/internally collapsed flexi. Stripdown (the brakes) before you buy anything!
Aug 24, 2009 19:00:26 GMT
right , pads are good , recently taken apart and cleaned , copper greased etc after the car has been dry stood for some time, although its done a few hundred sinse being on the road again
recent goodridge hoses , and I'm 100% sure its all the right bits n bobs
not spongey at all..why would the need to be bleed cause it to stick?
Last Edit: Aug 24, 2009 19:14:43 GMT by steveo3002
Aug 24, 2009 19:07:54 GMT
Piston has ingress of water and no rusty? Just bleed them either way, it's the only way to make sure everything works.
Aug 24, 2009 19:11:41 GMT
yeah will bleed em regardless ..my guess is its gone rusty
is working the piston in n out likely to fix it ?
Aug 24, 2009 20:32:34 GMT
Even if it doesn't, getting the pads out and 'exercising' it in and out is free and will hopefully give you some idea what's wrong.
Aug 24, 2009 20:35:14 GMT
As DW said, if the piston is to blame, it will go back in not so easily. Refurbing it shouldn't be too difficult (new seals and pistons).
if i can get the piston to move in n out...should it aslo turn fairly easy?
I'm guessing push it in with a g clamp or such then press the pedal to move it out again?
Hitch
Ive got vr6 brakes on my mk2 golf and when id first fitted them one of the pistons was sticking. Popped the piston out with a compressor, cleaned it up with some fine sandpaper then greased it all back up and slid it back in, didnt need new seals either as there was nothing wrong with them. If you take the piston out just check the seal for any tears/ deterioration. Pretty easy job to do once youve done it.
If you push the piston out with the caliper off the car you should be able to slide it back in again by hand, if not then its the piston sticking.
Last Edit: Aug 25, 2009 8:32:00 GMT by Hitch
Please don't take this the wrong way, but if you are having to ask what to look for on a siezed brake and not sure what to do I would personally advise you get a garage to look at it.
Brakes are probably the most impotant part of the car. If you're not 100% sure about what you're doing then please don't try and fix it yourself. Based on the above comments I would say that you're not 100% and therefore I urge you to take it to a garage (or get someone to help who is confident/competent with fixing brakes)
Hitch
if I can get the piston to move in n out...should it aslo turn fairly easy? I'm guessing push it in with a g clamp or such then press the pedal to move it out again? Its easier to tell if its sticking or not with the caliper off the car in my experience so its not under pressure. Also I cant remember if mine did or not but I don't think the piston will turn easily in the caliper anyway.
Please don't take this the wrong way, but if you are having to ask what to look for on a siezed brake and not sure what to do I would personally advise you get a garage to look at it. Brakes are probably the most impotant part of the car. If you're not 100% sure about what you're doing then please don't try and fix it yourself. Based on the above comments I would say that you're not 100% and therefore I urge you to take it to a garage (or get someone to help who is confident/competent with fixing brakes) theres no way a garage is working on my car...i do all my jobs myself and havent died yet I'm pretty confident doing jobs ive fitted lots of new calipers,pipes,hoses blah blah its just ive never had any caliper problems yet , so trying to gather some advice so I'm better informed when I get it apart
Aug 25, 2009 10:01:07 GMT
...i do all my jobs myself and havent died yet That's the attitude! Obviously my comment hit a raw nerve but it wasn't meant that way. Personally I'd rather swallow my pride/ego and get a pro to fix something as important as brakes if I wasn't 100% sure about fixing it myself. Based on your comments above, you obviously aren't 100% sure and for that reason I think you are being a bit narrow minded that you won't even consider a garage ever working on your car. I'm out.
Aug 25, 2009 11:03:29 GMT
I understand your concerns
I'm 100% happy to work on brakes , its just ive not yet had a caliper apart , so wanted some opinions on what to expect ....if I do have it apart and louse it up I'm happy to admit defeat and purcahse a rebuilt one or whatever it takes to be right
maybe i came accross wrong..I'm not a halfwit idiot with a couple of bent up spanners ...it will be safe
Last Edit: Aug 25, 2009 11:06:56 GMT by steveo3002
