Jul 13, 2010 18:40:14 GMT
It sort of does, the 2.3 box has the "standard" ratios. WTF is the bit at the end about attaching a stub to a standard gearbox though? There aren't any holes to bolt it onto and it protrudes into the main case, so unless you make a phoney cover from flat plate and tap some holes.. but then the bell won't fit. Seems a lot of faff to fake up a gearbox. edit autofive... er no, 2.5 consul/granada had an essex and a type E 4 speeder
Jul 13, 2010 19:50:09 GMT
It sort of does, the 2.3 box has the "standard" ratios. WTF is the bit at the end about attaching a stub to a standard gearbox though? There aren't any holes to bolt it onto and it protrudes into the main case, so unless you make a phoney cover from flat plate and tap some holes.. but then the bell won't fit. Seems a lot of faff to fake up a gearbox. edit autofive... er no, 2.5 consul/granada had an essex and a type E 4 speeder damn, my cunning plan is foiled
Someone just shot the elephant in the room.
Jul 13, 2010 19:52:10 GMT
My early mk2 Granny 2.8i Ghia S had a 4 speed manual box in it from the factory, was geared pretty high, would indicate 80mph in second gear if you thrashed it.
Jul 13, 2010 19:58:01 GMT
Yeah, the T9 didn't appear until sept 83, prior to that 2.8 granada and capri models got the "rocket" 3 rail box. Tall gearing would be the axle rather than the box tho...
Jul 13, 2010 20:03:50 GMT
What UK models did the Type F (3-arm sideplate) trans come in? All of our V6 Capris came with these. Alloy shifter base was remotely mounted on the floor pan via 3 rods.
Jul 13, 2010 20:25:06 GMT
according to my Ford transmission parts catalogue
Capri TL, TV Transit TV12, 13, 17 Taunus 12/20/26 EV, TV
plus thats what was used in the Scimitar GTE
Jul 13, 2010 20:25:18 GMT
Only the 2.0S mk2/3 capri (until '83) had a type F as far as I know, Norm. In an unrelated note, the linkages fell off one of these (in a capri) and stranded me on Gosforth High street one saturday evening in 1990. The young lady I was with got a taxi home, and never spoke to me again
Jul 13, 2010 20:28:52 GMT
so what (apart from the Zephyr / Zodiac) used the type Z box?
Last Edit: Jul 13, 2010 20:29:06 GMT by Autofive
Jul 13, 2010 20:31:39 GMT
Why? Is that what I tripped over this morning?
Jul 13, 2010 20:32:40 GMT
could be...........
Jul 13, 2010 20:35:09 GMT
In that case, I'd guess se5 scimitar, some random TVRs and gilberns, and my left boot
Jul 13, 2010 20:36:56 GMT
Only the 2.0S mk2/3 capri (until '83) had a type F as far as I know, Norm. In an unrelated note, the linkages fell off one of these (in a capri) and stranded me on Gosforth High street one saturday evening in 1990. The young lady I was with got a taxi home, and never spoke to me again I have 2 reactions to your post. First, all of our V6 Cappers used the Type F, as well as all of our Pinto 2.0L and Lima 2.3L Cappers. The only North America market EuroCapri that didn't use the Type F, was the Kent 1.6L Capris which used the Type 3. Second, I'm going to try your clever tactic with the dropped linkages on my wife. Could it really work? ;D
Jul 13, 2010 20:49:03 GMT
That's ford for you Norm, We got type 3 in the 1600, and rocket for the 3.0, same as the rest of the UK ford range except the 2.0, which got "zee german" box 2.0 cortinas of the same vintage have a HD type 3. I don't know about the second question. All I can say is shortly after that incident I met my wife, and it's been almost 20 years now
Jul 13, 2010 21:03:46 GMT
Some of the 3.0L Mk1's and 3.0L Mk3's got the Type 5. The Type 5 also was used in some of the RS2600's (other RS2600s got the Type F), and I just found another one out of a TVR imported over here. The Type 5 is claimed to be the baddest M-Effer trans Ford Europe ever put into a production V6 car.
Jul 13, 2010 21:08:36 GMT
Type 5? without a parts cat to hand, that sounds like the rocket ;D 3 rail box, torpedo shaped tail housing, long shift case over the top of the tail? reverse is down and right, by 4th? If so, yes, it's the great-grand-daddy of all strong v6 boxes ;D
Jul 13, 2010 21:17:16 GMT
Here's a Type 5, found in some RS's and 3.0L Capris: Here's a Type E Rocketbox, found in some 1.6L and 2.0L Capris, photo courtesy of Burton's. Burton's says this is a single rail, and we have these in the USA (in Mustang II and Pinto - the car Pinto) and I can confirm the Type E is a single rail:
Last Edit: Jul 13, 2010 21:28:45 GMT by Team Blitz
Jul 13, 2010 21:17:26 GMT
yes - according to my Ford parts catalogue (again)
the type 5 was fitted to
Capri EV30 Consul / Granada EV25, EV30
looks like the rocket
and in the parts list the TV2.6 is mentioned
Last Edit: Jul 13, 2010 21:17:56 GMT by Autofive
Jul 13, 2010 21:21:46 GMT
yeah I *may* have confused myself between a cortina 1600e box and the rocket .earlier (the separate shifter bit ) all I can say is it's late, I've been drinking and A5 has the parts catalogue... lol.
Jul 13, 2010 21:26:12 GMT
^^I'm just tryin' to help out with the Wiki, lol. Jagermeister? Guiness Stout?
Jul 13, 2010 21:37:07 GMT
and A5 has the parts catalogue... lol. **Genuine** transmission catalogue Normaccording to this 3-inch thick folder, respeldant in green plastic and chrome trim ;D entries for Capri; Type 3 (GB) KL13, KL16, TL16, EV20 from september 1970 onwards Type F (GB) TL16, TL20 from January 1972 onwards (D, or Germany) TV from October 1968 onwards Type 5 (GB/D) EV30 from August 1972 onwards Type J (GB) EV30 from August 1969 onwards
Last Edit: Jul 13, 2010 21:38:13 GMT by Autofive
